Old 10-11-2010, 05:03 AM
case-racing case-racing is offline
Default wild HP 300 rebuild
Well guys it's time to rebuild my much loved wild HP300 quad, so far i've rolled it, squashed 2 mufflers and twisted the balance shaft, after much reading i put the motor back together without the balance shaft which cracked all my engine mounts and learn't me a few lessons on vibration. so my question to you guys is while my majour rebuild is going on what mods should i do.
Old 10-14-2010, 03:02 AM
viktor_trx400 viktor_trx400 is offline
Vibrations are crazy without balance shaft, haha,
Old 11-11-2010, 04:49 PM
2stroker 2stroker is offline
A larger radiator is a must, if you want to run fast!
Have you fixed the upper a-arms, to correct the castor, and reducing rider arms fadigue?
Old 11-13-2010, 10:56 AM
h2oxer46 h2oxer46 is offline
What all is involved in the castor fix?
Old 11-15-2010, 02:49 AM
Cut the upper a-arms and install uniball bearings. Know you can adjusting the nuts to correct the castor angle to normal values, lets say 2 to 4 degrees. Original setup has about 20 degrees!
I will send you a picture of my quad if you want.
Old 11-15-2010, 05:14 PM
Sent you a PM 2stroker. Thanks
Old 11-15-2010, 09:00 PM
hudson_hollow hudson_hollow is offline
I put the 2006 A arms on my 04 and they work great.
Old 11-16-2010, 07:34 PM
What is the difference between the two? I have an 03
Old 11-17-2010, 02:24 AM
The 2003 to 2004 have 50" wide a-arms. this is the first series.
From 2004 to 2006 are 2 options: first series or 48 " a-arms to make the front end of the quad narrower.
Old 11-17-2010, 07:17 AM
They also get the camber to 10 degrees which works well. I put 4-1 Hipers up front to suck it down a little more and it works great here in the Eastern woods. It's now around 47".
I wish Gas Gas would go back to the 300 engine in their quad. Everyone makes a good four stroke quad. They just never developed a market for this great machine.
Need help on top end rebuild rpduc Enduro Engine - 2 stroke 17 03-26-2009 11:05 PM
300 Hp Wild Engine Rebuild!?!? GASGAS300HP Enduro Engine - 2 stroke 2 03-16-2009 12:08 PM
rebuild intervals mountain thumper Enduro Engine - 2 stroke 16 07-29-2008 03:04 PM
05 rebuild brains Enduro Suspension 2 07-22-2008 08:54 AM
Rebuild steve Enduro Engine - 2 stroke 8 01-13-2008 03:06 PM
