Old 07-11-2007, 07:31 PM
Crankin04 Crankin04 is offline
Question Km to Mph for 04' GG 450FSE
Anybody know how to change from Kilometers to Miles-per-hour for 04' GG? Thought it was something with a chip upgrade on the display but apparently not.
Thanks,
-Chris
Old 07-12-2007, 06:16 AM
eff's Avatar
eff eff is offline
Copied from the manual.
You can download it here:
http://www.gasgasmotos.es/rcs/manual...04_fse_eng.zip
To change to kilometers per hour or miles per hour:
- Disconnect the battery. (the total distance will be saved).
- Re-connect the battery whilst holding down either button and it will
read either;
met -- for km/h
mil --- for mp/h
- The white plastic block connector on the speedo is for the display
backlight.
- The red wire is positve.
- The black wire is negative.
- Warning; your speedo is set for the diameter of your front wheel
enduro 21"
supermoto 17"
If you get the display to read "a 00" then you are in the rolling radius
changing mode. you can "trim" the speed to run fast or slow.
It ranges from "a-25" to "a 25".
NOTE
Standard setting is "a 00", we recommend you keep it at that.
0.0
Trip distance
0000
Total distance
Old 07-13-2007, 10:49 AM
Great, Thanks. I will give it a try.
Old 07-13-2007, 06:17 PM
McGuiver McGuiver is offline
I have an 05, and that did not work for me.......anyone else try that?
Old 07-13-2007, 09:02 PM
Nick's Avatar
Nick Nick is offline
Keep trying, it works
Old 07-13-2007, 09:23 PM
John_B John_B is offline
Does that work for ealier years also? (03?)
John B.
'03 GasGas FSE 400
'97 Honda CR 250
'02 Honda VFR800
Old 07-14-2007, 06:23 AM
Brian VT Brian VT is offline
It works on my '03.
Old 07-14-2007, 07:29 AM
Fire Escape Fire Escape is offline
Default Yes, keep trying!
I don't know about the second section i.e. match ing tire size etc. But disconnecting then reconnecting the battery while holding the button worked on my '05 FSE.
Also, if you don't already have a Battery Tender wired on the bike - Do It Now, my plug is ty-wrapped to the frame, just inside the air box door so it's quick and easy to access which is important on a bike that NEEDS to live on life support (maybe it doesn't IF you can ride it often). Perhaps someday I'll look into adding a switch to turn off the speedo, etc. and the battery will last more than two weeks, kind of busy right now so it gets ignored, and doesn't like that much.
Bruce
No one ever calls the Fire Department because they did something smart
Old 07-17-2007, 09:48 PM
flybars flybars is offline
Also the battery tender keeps your battery fresh thru the winter. If U don't use one during this weather period U will be buying a new one. Ask me how I know.
'14 Beta 300rr
'05 GG DE300
'03 GG EC250
'01 XR440
'09 FZ1
Old 07-22-2007, 05:26 PM
Well, after my second attempt, I actually did get MPH to register on my speedo. Next question is, does the ODO still read in Km., or does that switch with it? I'm thinking it stays in Km., but not sure. It would just be nice to know if my bike has 500 Km.s or 500 miles on it for examle.......
slip-on 450fse? johanpe Enduro Engine 4 stroke (including EFI & Exhaust) 11 07-26-2010 11:24 AM
oil sensor 450fse 03 jjbaker1 Enduro Engine 4 stroke (including EFI & Exhaust) 1 03-12-2009 05:54 AM
450fse tuning jjbaker1 Enduro Engine 4 stroke (including EFI & Exhaust) 9 03-09-2009 04:40 AM
