Hey all, going tomorrow to pick my GP up from the shipper
![]() ![]() ![]() TIA
Dick Carnes "If ya run, you'll only die tired" 2019 EC 300 2018 GP 300 2013 XC 300 (sold) 2006 DE 300 (buddy has it) |
That's funny you want to add and I want to eliminate, I just spent a good amount of time trying to find a way to eliminate the stock dashboard without cutting into the wiring harness. Can't find a male connector that will fit in the main harness female connector.
I would just put it in line with the kill switch, off would be to ground. Would still turn over but never fire. |
The White/Blue wire to the coil would work.
The ignition switch should have several lugs, you can kill power to the starter too. |
adding oil to Shivers.... | houndog | Enduro Suspension | 4 | 04-14-2014 03:36 PM |
Adding an E-start | desertgasser300 | Enduro Electrical & Wiring | 8 | 11-13-2013 07:00 AM |
adding a battery for HID | bonkeye | Enduro Electrical & Wiring | 5 | 11-27-2012 01:14 PM |
2k-3 Swap and adding headlight | Brian | Enduro Electrical & Wiring | 28 | 10-21-2010 11:29 AM |
Adding another gasser to my stable | joey11 | General Discussions & Announcements | 0 | 05-15-2008 12:11 PM |
