Old 02-10-2020, 12:43 PM
Hooligan Hooligan is offline
Default Shock Crossover?
Any idea what shocks might fit a 2010 EC250F?
I cannot imagine this shock is a GasGas only item. It must be used by another company somewhere?
Old 02-10-2020, 06:08 PM
frankinberg's Avatar
I have a 2011 gasgas 250 f it's the same shock as the 2011 2 stroke just had mine revalved your is the same ohlins 888 or Sachs will work
Old 02-11-2020, 12:10 PM
The reason I asked about shock crossover with other bikes is that I just had the OEM shock serviced and it turned out the shop could not source some of the seals.
I ended up machining the seal seats to a larger size so that more common seals could be used. However it got me thinking if that shock ever dies what could it be replaced with?
GasGas must use a shock that is also used in another brand of bike?
Old 02-12-2020, 07:05 PM
coopernicus's Avatar
coopernicus coopernicus is offline
I don't know if this is exactly the answer you are looking for but I have used a 1999 Kawasaki KX 250 KYB shock on my older Gas Gassers. I had one on a 2001 300 and I believe it would have fit my 2007 as they "looked" the same. Those should be a similar shock to the 2011. The KX shock is a little bit shorter so I got some shorter (I think?) dog bone links for the suspension. Frankly, the KX shock worked much better than the stock Ohlins. I think the '99 KX shocks work on '97-'02 KXs (I think 2003 KXs, too, but I have not tried it yet). Please note: You cannot use KX shock parts in the stock GG shock.
2018 GG 300 GP
2014 GG 300 Racing E
2002 ATK 605 Dual Sport
2003 KX/KDX 220 hybrid
2021 Kawasaki KRX 1000 Trail Edition
1974-86 Vintage Can Ams, SWMs, Puchs, etc.
Old 02-12-2020, 09:10 PM
SS109 SS109 is online now
Originally Posted by coopernicus View Post
...I think the '99 KX shocks work on '97-'02 KXs (I think 2003 KXs, too, but I have not tried it yet)...
I can confirm that the '02 will fit an '03 KX250. Did the swap since the '03 shock didn't come with high speed compression like the '02.
Hooligan, talk to a suspension tuner and compare the GG shock with shocks he has. I installed an '01-'06 Suzuki RM125 Showa shock (with a Honda XR400 lower clevis) into my Kawasaki KDX220 chassis which came with KYB. I know it's not a GasGas but it shows what you can do if you take the time to compare and figure it out.
Old 02-24-2020, 11:59 PM
I'm a little bit surprised there is not an obvious and easy shock swap. I cannot imagine the shock is specific only to GasGas.
For now the shock has been rebuilt and will last for the foreseeable future. The internals have been modified to allow the use of more common seal sizes so t should be able to be serviced again. Just worried that some of the harder to find parts might wear out and leave me stuck.
Old 02-25-2020, 08:07 AM
Watch eBay pick up a Sachs or ohlins 888 for a spare there should be plenty out there 07-11 will work
Old 02-25-2020, 09:54 PM
rvktm rvktm is offline
k tech uk do most of the sachs seals or skf do a seal block
Sachs shock ec 300 2010 crossover? adriano.ro Enduro Suspension 12 06-19-2019 03:18 PM
Crossover shock? Jonas300 Enduro Suspension 3 01-13-2019 02:56 PM
Top shock bush crossover? swazi_matt Enduro Suspension 11 03-25-2016 08:45 AM
Sachs shock spring crossover? n_green Enduro Suspension 4 04-15-2013 04:27 PM
rear mudflap/shock guard crossover ? Brian VT Enduro Chassis & Body 1 06-19-2007 01:23 PM
