Old 11-11-2008, 03:50 AM
Bearman's Avatar
Bearman Bearman is offline
Default Hot start problem???
Hey guys, I have a little bit of a problem at the moment.
My '03 EC200's been running awesome, but just over the last 2 or 3 rides, it will not kickstart once the engine is warm. I can pushstart it though
The first two times this happened, the air temperatures were around the 29-32 degrees celcius mark. So I thought maybe it was just because of jetting not quite right, but it happened again this weekend, and it was around the 16 degrees celcius mark, in areas where this was never a problem.
Does anyone have any thoughts as to the cause of this problem? I am going to check float levels and carby settings this weekend, its strange as this problem came on extremely quickly.
Thanks guys.
Ben
'03 GasGas EC200 My bike
'89 Yamaha TT250 R.I.P - Lost in the Black Saturday Fires
Old 11-11-2008, 06:49 AM
Check the reeds, ignition coil, and CDI in addition to the carb. If the bike starts good cold, heat the coil and CDI with a hair dryer and then try it, if the reeds and carb check out OK.
Old 11-12-2008, 01:21 AM
Bearman's Avatar
No worries, thanks GMP. Ill give that a crack, what should I check in the carb? Float level? It went off to quick to be the actual jetting I reckon.
Thanks again
Ben
Old 11-12-2008, 10:06 AM
Float level, leaking float valve, loose brass. If its a fuel problem, it seems like a too rich fuel problem, as it starts good cold. Think about things that could cause a rich condition.
Old 11-12-2008, 12:32 PM
Loosenut's Avatar
Loosenut Loosenut is offline
Great suggestions! I find that canned freeze spray can work wonders for troubleshooting. Get the bike hot and hit each item individually with the freeze spray. If everything else listed is OK, then I would place money on the stator. Canned air turned upside down will act as a freeze spray.
Mike Baxter
2005 GasGas EC300 (Ohlins front and rear)
2007 Yamaha FZ1
2003 Pampera 280(hers)
Old 11-13-2008, 08:36 PM
Bearman's Avatar
Thanks guys, not riding this weekend and have a whole heap of spare time on my hands, so I'll pull the craby apart and have a look.
Thanks again guys, you're all being really helpful
Ben
E-Start Kit aflica General Discussions & Announcements 6 04-26-2013 05:57 PM
Kick Start 07 FSR 450? GavGav Enduro Engine 4 stroke (including EFI & Exhaust) 18 04-08-2011 04:33 AM
450 won't start please help Oldcow General Discussions & Announcements 41 08-29-2008 09:21 AM
Where to start and Merry X-mas!! 3hunerd Enduro Intake/Carburetion - 2 stroke 3 12-27-2007 07:09 PM
When did it all start? Anarchist General Discussions & Announcements 4 07-22-2006 05:49 PM
