Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > "Wanted to Buy" & "Want To Trade"
"Wanted to Buy" & "Want To Trade" Bikes or Parts
Old 11-25-2018, 07:36 PM
jt633 jt633 is offline
Default wtb 2009 front wheel + spacers+ axle
looking for a 2009 front wheel plus spacers and axle. going to put 09 sachs forks on my 2004 thanks
2004 ec 300
Old 11-25-2018, 09:07 PM
Any wheel from any year will work
Old 11-26-2018, 05:44 AM
Good to know, I still for sure need the wheel spacers though as I modified mine to use a custom ohlins fork and it's not working properly
2004 ec 300
Old 12-02-2018, 07:36 PM
so i put the sachs 2009 model forks on the 2004 and the axle will not fit the wheel. the sachs 48mm axle measures 24.93 mm and the 04 measures 20mm
2004 ec 300
Old 12-03-2018, 01:09 AM
Anders Anders is offline
Yes, they went from 20 to 25mm front axle in 2005 or perhaps 2006. But the hub is the same, only bearings and spacers changed. So what you need to do is to replace bearings, seals and spacers.
According to the 2015 spares list, the 2015 bearings are 6905 - 25x42x9mm. I use the same wheels on the 2006 and 2015 bikes. I can check the bearing number against the ones I have in my spares bin when I get home.
Old 12-03-2018, 03:19 PM
Quoting myself here... The bearings I have in stock for my own wheels are SKF and FAG 61905, not 6905. I don't know what the difference is, they share the same dimensions - 25x42x9mm.
'06 EC300 ajs front wheel spacers brider Enduro Chassis & Body 10 04-11-2013 08:40 PM
Front wheel spacers. iamyvr Enduro Chassis & Body 4 02-22-2013 10:09 PM
20mm Front Axle Spacers Mattnzl Enduro Chassis & Body 3 10-02-2012 04:23 PM
Front Axle/Wheel Removal gasIdaho Enduro Chassis & Body 1 02-15-2007 08:31 PM
