Old 03-24-2014, 10:43 AM
EC250's Avatar
EC250 EC250 is offline
Default Marzocchi shiver 45mm to fit 1997 EC 250?
Hi can anyone tell me if Marzocchi shiver 45mm forks would fit
My 1997 EC 250 with right Yokes ?
Cheers for any help
Old 03-24-2014, 10:49 AM
Banned
Cheers for any help
Yes, but you need the triples, front tire/axle and brake caliper. For the money and time it took, it would be better to source out KYB's from a Yama.
Old 03-24-2014, 01:53 PM
EC250's Avatar
Ok, what I meant to put was, is the 2002 Axel and brake Caliper (Nissin)
I already have fitted to allow the WP forks fit my bike the same Axel and brake Caliper needed to fit the Marzocchi shivers, so provided I have the 45mm Tripels
Everything should fit ?
Old 03-24-2014, 02:07 PM
pj7's Avatar
pj7 pj7 is offline
The caliper will be fine. The axle diameter on the WPs is different. WP uses a smaller (20mm I think), Shivers is larger (25mm I think). You'll need a axle from a 2004 or newer bike, axle nut, wheel spacers, bearings, seals, and the spacer between the wheel bearings. The hub is fine, the I.D. of the bearings changed when they went to the Marzocchis but the O.D. of the bearings stayed the same.
Old GGs: 01 XC300, 02 XC125, 03 DE300, 03 DEO200, 01 SE300, 2011 EC300
Current: 05 DE250, Showa forked frankenbike 300, 05 DE300, 19 YZ250X
Old 03-24-2014, 02:22 PM
EC250's Avatar
Ok, cheers for that pj7 looks like ebays the next stop !
Old 03-27-2014, 08:33 PM
EC250's Avatar
Hi, I'm found some 1998 45mm Triple Clamps off an EC 250, will these fit the Shivers as they are also 45mm or would I need the yokes from the same year as the Shivers, which is 2007, cheers for any help
Old 03-28-2014, 12:23 AM
Elvis74 Elvis74 is offline
1998 gasgas used the marzocchi magnum fork which is a standard and no usd fork. Make sure you are looking for the right triple clamp. 2000 gasgas changed to the usd white power 43mm and 2 or 3 years later to the shiver
Old 03-28-2014, 01:36 AM
EC250's Avatar
Ok, cheers for that, so your saying that although the Triple Clamps that came
With the 1998 & the Shivers were both 45's, only the ones that came with the Shivers will fit the Shivers.
Old 03-28-2014, 01:42 AM
Yep,
check out www.gasgasmuseum.com
here is the 1998 Enduro
http://www.gasgasmuseum.com/bikes/im...0sixdaysLt.jpg
This is the one you need to mount the 45mm Shiver fork.
http://www.ebay.de/itm/171272095865?...84.m1423.l2649
Old 03-28-2014, 02:17 AM
EC250's Avatar
Cool, cheers Elvis74, If I could read German, I would have snapped those up !
wtb marzocchi shiver 45mm mbogage "Wanted to Buy" & "Want To Trade" 7 04-06-2014 09:46 AM
Marzocchi 45mm shiver forks 200e Jiikoo811 Parts 0 01-26-2014 12:48 PM
wtb marzocchi shiver 45mm mbogage Parts 1 01-12-2014 09:21 PM
Marzocchi Shiver 45mm piston mcnut Enduro Suspension 7 01-15-2012 08:40 AM
Marzocchi 45mm Shiver manual super_rat Enduro Suspension 1 01-01-2009 10:24 PM
