Old 03-09-2020, 04:16 PM
Mikesbaron Mikesbaron is offline
Default How do I remove stator cover? (4-stroke)
2007 FSR450
I need to replaced pulsar sensor coil, which I already have in possession. How do I get the damn stator cover (left) off? I removed starter, removed small cover bolts and then removed the big nut holding it on.
Do I need a flywheel puller? Because I also tried ordering a 27 and a 28 mm external thread flywheel puller and no dice, neither of them fit. The 27 mm was too small and the 28 mm was the internal threaded one. I can't find a 29 mm external thread. Some guidance is much appreciated.
Old 03-10-2020, 03:15 PM
does the exploded view help?
https://gasgas.com/en/manuals?c=enduro&y=2007
Old 03-10-2020, 03:51 PM
No that diagram is not the same as mine. My left side cover has a threaded innner area. I'll try to take a pic tonight.
Old 03-10-2020, 05:23 PM
by stator cover do you mean the flywheel? yes you will need a flywheel puller for that, I believe that motor started life as a Suzuki DR-z so take a look for the specs of the DRZ flywheel puller.
Old 03-10-2020, 07:42 PM
I measured and it appears to be 29 mm with a 1.5 mm pitch. I cannot seem to find anything doing multiple keyword searches on Amazon and fleabay.
See pics attached.
Old 03-11-2020, 03:43 PM
looking at the exploded view (pg72) it looks like a big cover, so you may not have all the bolt off, i also see some dowels, I have had problems with those previously where they corrode and seize
Old 03-11-2020, 04:27 PM
I'm 99% sure I have everything unbolted. I've tapped on it with a mallet for a while and no movement. I just ordered an external thread flywheel remover kit and it looks like it might have the one I need to push it off.
Stator cover adv rider Enduro Engine - 2 stroke 1 04-30-2014 10:19 AM
Remove valve cover - Impossible [450 SFE -05] luzt Enduro Engine 4 stroke (including EFI & Exhaust) 2 02-18-2013 06:52 AM
Gear lever - cant change up, rubbing on stator coil cover KTMAndy Enduro Chassis & Body 7 04-05-2012 09:38 AM
how do you remove the kickstart noobi Enduro Chassis & Body 13 09-22-2011 03:31 PM
