Old 07-09-2008, 10:33 AM
mountain thumper's Avatar
mountain thumper mountain thumper is offline
Default rebuild intervals
was just looking over some older posts and came across a scary post.
someone was saying how theyd ridden 50 hours without needing a rebuild.
my bike is apprx 30 hours old. im going to be seriously peeved if i have to dump another few hundred in it that often!!!
we had an old (and free) yami enduro, when we got it, cylinder was seized. poured motor oil into it, let it sit a week, got the little turd to pushstart! never did any other work to it other than replacing a crap-ton of levers, rode it for 2 years before i moved and got my first xr.
how often does a gg 2t need rebuilt? i barely ride mine, and when i do, i take it easy. i cant afford a rebuild a year!
Le Crutan
98 ec250 sixdays, doma, eline pipe guard, zokes shivers from a cr250,fredette racing chain slider, protaper withbarkbusters (SOLD)
FOR THE SECOND TIME 07 EC300 polisport headlight, acerbis taillight ltr pv cover and case saver,trailtech endurance,120z fww, g2 throttle,xr chain puck:
Old 07-09-2008, 11:16 AM
2 strokes 4 life's Avatar
Mine is a 2002 with well over 100 of hard hours and when i took it apart all it needed was a hone, cleaning power valve parts, and new rings. I think when i start racing next year i am going to put in a new piston that is slightly larger. In total with all new gaskets and what i listed it was only $150 at tops.
2012 Ktm 300xc
2001 Gasgas EC300
Old 07-09-2008, 11:19 AM
JoshP's Avatar
JoshP JoshP is offline
How much riding is not that often? On my 98 I rebuild every year or 2 but I'm riding every Sunday, 1 night a week during summer and every Sunday all winter (only missed 4 weekends last year.). On my backup 97 I'm still sporting the original 97 piston and rings setup. Now this last year 07' I'm estimating around a little under 250 hrs on the top end (98) and it still looks good going into this season so I will hold out as long as possible. Continued carb cleaning will keep most crap from getting into the head and messing up your piston. I typically remove and clean the carb after 2 to 3 rides. During this I remove the reeds to check and inspect the whole assybly to the intake to verify no dirt is in there. Obviously this sucks to do but it way less cash (FREE) compared to a new top end. Take you front pipe off and check what shape you piston is in now and that should give you a good idea of how much time you have left on it.
Old 07-09-2008, 11:21 AM
JoshP's Avatar
2StrokesForLife.
I love your bike photo of the old Yama. I still have my
79' IT 175 in the basement and take it out for a vintage
knee beating every once in a while.
Old 07-09-2008, 11:38 AM
Eric K Eric K is offline
Keep your air filter clean and well oiled.
At 50:1 mix, I have gone as long as 120 hours between top end rebuilds with no ill effects other than moderately reduced compression.
I increased my oil in the pre-mix to 38:1. I get 90 - 100 hours with only 2-3 psi compression loss.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 07-09-2008, 04:03 PM
Originally Posted by JoshP View Post
2StrokesForLife.
Thanks man. The display pic is a 1981 IT465. I am in the process of rebuilding it into a hill climber. I will post pics of it next spring when i am done. The 175 also needs some work. Fun bikes for the age.
2012 Ktm 300xc
2001 Gasgas EC300
Old 07-09-2008, 10:34 PM
I pulled the top end off my 06 300 with about 60 hrs on it. All it needed was rings. Unfortunately I seemed to have some kind of mystery piston and could not get a set of rings to work with the original piston so ended up with new piston also. In fact the jug had so little wear that the first wiseco piston sent to me was too big for the jug ... even tho that was the only piston wiseco made for 00 to 06 gassers. ended up using a piston for an 04 gasser. A buddy of mine said ... do a compression check ...if it is good go ride!! I think thats going to be my approach in the future. I'm not rev happy tho and ride slow tight woods
Old 07-27-2008, 10:53 AM
ricegas ricegas is offline
My 99EC300 still has stock piston and rings...never felt the need to pop the cherry on the topend yet. I don't ride every weekend, but usually 1-2 times a month if work and family allow time. I've been careful about air filter maintenance and trans oil changes, airfilter changed every ride and oil every couple. Run the bike 40-1 with-don't laugh-Honda HP2 and have never had a fouled plug or jetting issues. It runs like a top still, just as strong as my buddies "new" 05 ec300.
Old 07-27-2008, 11:14 PM
i got a bunch of dirt in the pipe during a rollover, so i took off the pipe and silencer, the piston looks ok, and what i could see of the rings was good. looks like the piston has some kind of friction coating thats worn under the port.
Le Crutan
Old 07-28-2008, 02:50 AM
stay_upright's Avatar
I asked my local dealer how often i should replace the rings on my 05 300 and he said never! I checked compression at 150psi which seemed low compared to my KTM 200. I changed the rings (first time for the bike I think) and compression was 150psi tells me my dealer was right - no noticeable wear. I used to change piston and rings once per year on my KTM 200.
Buy a compression tester - measure compression now check every 3 months if it drops off 10-20psi and you feel like you want more power change the rings.
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
rebuild time?? W8TSON Enduro Engine - 2 stroke 10 08-02-2009 02:05 PM
Need help on top end rebuild rpduc Enduro Engine - 2 stroke 17 03-26-2009 11:05 PM
05 rebuild brains Enduro Suspension 2 07-22-2008 08:54 AM
Fork Oil Change Intervals GG27 Enduro Suspension 3 06-02-2008 03:41 PM
Rebuild steve Enduro Engine - 2 stroke 8 01-13-2008 03:06 PM
