Gear box problem 07 ec300
well i said i would report on my ride with the sachs shock - you can find that info in suspension - a far greater problem is that i have only third gear, cant change up or down, the lever is has spring tension but will not do anything.
The bike hasnt reached 200 klm yet so you can guess how pissed off i am and its funny i was thinking 10 mins earlier, what a brilliant gearbox. My boy has had no luck with his new 06 200ec the tacho died and we found cracked and broken wires - i suppose he will post the photos and a story on the forum. |
Starter clutch / gear problem | iancp5 | Enduro Engine 4 stroke (including EFI & Exhaust) | 12 | 01-28-2011 02:45 PM |
gear problem | new gas gas | Enduro Engine - 2 stroke | 2 | 01-06-2009 09:53 AM |
EC 125 Gear Shifter Problem | jonnyweston | Enduro Engine - 2 stroke | 6 | 09-17-2007 11:41 AM |
ec125 2002 changing gear problem ? | fastfilli | Enduro Engine - 2 stroke | 8 | 05-20-2007 09:13 AM |
00 GasGas EC300 Gear Lever | Gasser370 | Enduro Engine - 2 stroke | 20 | 03-27-2007 10:19 PM |
