Old 05-28-2016, 03:22 PM
Thumbs up OBIE link guard
My rear shock is taking a beating from crossing logs etc.
No one ( that I know off) makes a link guard for the newer GasGas'.
After doing some research, I found the http://www.obielinkguard.com/
They don't make a GasGas specific guard.
So I purchased one for a BETA 250RR.
It mounted up very well.
I had to shorten the rear part of the guard 3/4". I also had to use a longer mounting bolt for the rear skid plate mount.
New mounting hole drilled for rear skid plate mount.
Hole drilled for oil drain. The two mounting bolts fit between the frame with no clearance issues.
Shock not hitting plastic plate.
Old 05-28-2016, 07:25 PM
barossi73's Avatar
Nice work!
What was the $?
I have a p3 bash plate,which uses a rear mount which cups the rear chassis rail,so most likely id need to butcher it some to make it fit.
2013 ec200r
Old 06-01-2016, 09:59 PM
The guard is $44. It is some tough plastic.
You do need a flat surface for the guard to bolt on to.
Old 06-01-2016, 11:27 PM
shang shang is offline
This is a sweet solution! At $44 it's a better deal than building your own like I've been doing. Thanks for taking the risk to try it out and thanks for sharing!
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1983 Yami Tri-Zinger
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 06-06-2016, 09:36 PM
You're welcome.
Anything to help out my peeps.
Old 04-19-2018, 01:31 PM
kdxkid kdxkid is offline
Originally Posted by gasgasman View Post
You're welcome.
Sorry to dig up an old thread... but do you think this would work on a 2011 EC300? I have the stock plastic skidplate installed.
Thanks
Old 04-19-2018, 02:32 PM
I don't see why it won't work.
Old 04-19-2018, 03:03 PM
Elvis74 Elvis74 is offline
I don’t see why you need one on the old gasser? When you compare the old with the new linkage you will see that the old style is different and will not touch any obstacle.
Gesendet von iPhone mit Tapatalk
Old 04-19-2018, 04:09 PM
john r b's Avatar
john r b john r b is offline
Same linkage 11'- 17'
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 04-19-2018, 04:39 PM
Originally Posted by Elvis74 View Post
I don?t see why you need one on the old gasser?
It keeps mud and water off the linkage.
master link pigpen966 GasGas Member Polls 22 03-25-2015 03:53 PM
lowering link help please byost Enduro Suspension 5 01-17-2013 12:44 PM
is there a master link? mountain thumper Enduro Chassis & Body 4 07-09-2008 05:36 AM
Clutch link brains Enduro Chassis & Body 1 12-31-2007 03:04 AM
Broken Link Dingo Enduro Engine - 2 stroke 3 07-07-2007 07:15 PM
