Old 08-31-2006, 09:07 PM
sn22 sn22 is offline
Default Suspension fastener and shock problem
Well, just like everything in life when things go good they go really good and when things go bad, they go really bad!!
I just purchased this used '00 300 EC last Saturday and have been going thru it this week. All seemed in good working order until tonight when I took off the shock and the forks because I was heading to my suspension guy tomorrow to have them revalved and sprung for my weight for a ride on Sunday. Well the problems started when I took off the lower shock bolt and I heard a peice of aluminum hit the floor, the bottom clevis on the shock is broken. The ear broke off where the bolt goes thru. Looks like its been broken for a while judging by the dirt on the crack......so then I finish taking it off and clean it up. On to the front forks and I am soon to discover a broken fork pinch bolt on the upper left and the two bottom bolts on the lower tripple clamp will not come out for anything!!!! I tried penetrant and heat to no avail. I did not want to break another one off so Im going to borrow a buddys 1/4" impact and get a socket mounted allen key and some easyouts and try that....if it breaks it breaks I guess.........ugh.....so I go from looking forward to riding this weekend on my "new" old bike with a fresh set of S12's and reworked suspension to typing up this long winded rant!!!!!!!!! My saving grace is that my buddy stores his '01 CR250 at my house and he's out of town so looks like Ill be flogging that on Sunday .
Any tips on the allen pinch bolt removal would be appreciated. Has anybody replaced these with regular 8MM or 10MM headed bolts?? OK, Im done whining please return to your regularly scheduled program
Old 09-02-2006, 12:45 PM
LTRace's Avatar
LTRace LTRace is offline
More than likely, your lower clevis broke because your lower shock mount is sopposed to have 2 cup shaped washers that also act as spacers. I bet one or both are missing.
As far as the triple clamp bolts, they pretty much suck unless you apply anti-sieze compound to the bolts when they are new and then keep up on them. It seems the cad plating and bare cast aluminum love to become one. You need a savvy mechanic/machinist for the fix.
Les
www.lt-racing.com
Port Orchard, WA USA
Problem IDing/Baselining Ohlins Shock GasGasDreamer Enduro Suspension 3 03-31-2015 03:18 PM
ohlins rear shock problem reeve Enduro Suspension 14 06-01-2014 11:03 PM
suspension problem GASGAS 300 RACING 2009 EMIL Enduro Suspension 7 04-03-2009 06:39 AM
EC 200 Suspension Gas Huffer General Discussions & Announcements 3 11-13-2007 10:34 AM
Suspension FAQ webmaster Enduro Suspension 12 09-18-2006 03:56 PM
