Trials Intake/Carburetion - 2 stroke Jetting, Reeds, Air Filters, etc. |
I've been trying to solve an issue with my 97 JTX 270 and can't seem to pinpoint it. It runs borderline OK when I just start it and then gets very lean and it's not the carb - I've rebuilt it and it is clean, new float valve, etc. I also replaced the crank seal behind the stator and put in new reeds. It seems to me that there is either some other air leak I need to find or I have a problem with my gas flow from the tank. I'll take off the tank and check that but I don't think that is it as I get plenty of flow out the fuel hose and have replaced the filter I have in line.
Any ideas? Should I seal up the motor and look for leaks? Thanks
11 Husaberg 570 12 Husky 310 97 Gas Gas JTX 270 trials 10 Beta Evo 290 trials 02 E440 Cannondale plated |
check intake rubber for cracks
The carb has a filter on it at the fuel inlet have you cleaned it?
Thanks for suggestions. I've cleaned and rebuilt the carb completely but did not look at the carb boot closely - I'll check that tomorrow. If that doesn't locate an issue I'll try to pressure and vacuum test the motor.
Jim Snell would be more than happy to help you he is the former importer for gas gas you can contact him at trialspartsusa.com
How to know if the bike is running lean? | Munch | Enduro Engine - 2 stroke | 66 | 06-30-2021 03:08 PM |
Blue/Yellow Wire on ECU/running lean???? | Why Z? | Enduro Engine 4 stroke (including EFI & Exhaust) | 4 | 10-02-2015 04:22 PM |
Strange issue. Need advice. | FDB | Enduro Intake/Carburetion - 2 stroke | 6 | 07-20-2014 03:04 PM |
Steep uphill running issue | (F5) | Enduro Engine - 2 stroke | 8 | 01-27-2013 04:10 PM |
12 300 running strange | shark4465 | Enduro Engine - 2 stroke | 21 | 01-05-2013 08:20 PM |
