Old 11-23-2012, 03:49 PM
uwynn77 uwynn77 is offline
Default standard jetting info please
Can anyone tell me the standard jetting and carb specs for my 2007 EC 125? Thanks!
Old 11-24-2012, 04:56 AM
hannesd hannesd is offline
turn the carb to the side and unscrew your flaot bowl and undo your jets and see for yourself.
if you're going to replace them you'll have to do that anyway.
who knows what the previous owner put in?
and even if it was bought new by you, you still best check it for yourself.
thats why quite a few people looked at your thread but didn't leave a comment.
ciao, Hannes.
Old 11-24-2012, 01:03 PM
well that makes sense, the previous owner has rejetted it and Im not sure what he took out.
Old 11-25-2012, 05:01 PM
Jetting is 48 and 178. Does that sound right for a 125?
Old 11-25-2012, 05:21 PM
bowhunter007's Avatar
You'll need to provide some info, in order to even venture a guess. Altitude, general climate(common temps, humidity, etc.), You'll also need to know which needle you currently have. Jakobi will probably have the best info, for a start. If you are lucky, someone here rides a similar bike, under similar conditions and will chime in.
Old 11-27-2012, 04:44 AM
No idea what a starting point would be for a 125, but it'd be expected to be a bit richer than a 250/300 for sure. The best way is to provide as much info as you can. Current settings (carb size, pilot, main, needle and clip pos, slide number) and conditions (altitude, temps, fuels, oil ratio, etc) and then.. how the bike runs now, and how you'd like it to run. The more info you supply the more likely people will be able to chime in with suggestions.
Tags
jetting
info on getting jetting right from JDean re vibes Simmo737 Enduro Intake/Carburetion - 2 stroke 4 08-01-2012 06:31 AM
Hi all off you GG riders I need some jetting info hilmirb@simnet.is Enduro Intake/Carburetion - 2 stroke 0 12-12-2009 02:30 AM
Standard Jetting macho comacho Enduro Intake/Carburetion - 2 stroke 3 10-13-2009 12:15 PM
2003 uk ec250 standard jetting woody1965 Enduro Intake/Carburetion - 2 stroke 0 10-04-2009 02:41 PM
What is the standard (emissions) jetting as new ? stay_upright Enduro Engine - 2 stroke 11 07-08-2008 11:18 AM
