Old 11-14-2017, 11:46 AM
ssaulnier's Avatar
ssaulnier ssaulnier is offline
Default Remove Compression Adjuster Sachs Shock?
How do you remove the compression adjuster from the Sachs shock on a 2007 EC300? I have the shock apart and the adjuster knob off, but do not understand how to remove the compression adjuster assembly for cleaning.
It has some old crusty white grease in it that makes the adjuster hard to turn (or something else).
Seals and orings look good. Oil was a little dark but not too bad.
Thanks in advance, Steve
Old 11-14-2017, 04:27 PM
Have a read HERE
Old 11-14-2017, 06:26 PM
ssaulnier's Avatar
Jake, You are THE MAN! I am a happy camper now! Thanks, Steve
Old 11-14-2017, 11:54 PM
Just keep tabs on those springs and ball bearings. Small little suckers.
Is there an easy way to remove the rear shock? rgranger General Discussions & Announcements 18 09-05-2017 04:59 AM
Looking for SACHS front fork rebound adjuster GAS GAS 250 2011 dimtsam Enduro Suspension 12 10-07-2014 01:41 AM
Rebound Adjuster knobs? 45mm Sachs Bark3rd Enduro Suspension 5 01-29-2014 10:21 PM
Sachs shock compression adjuster? SpeedyManiac Enduro Suspension 2 03-26-2010 02:13 PM
Seized Compression Adjuster on Marzo 45's Gasser200UK Enduro Suspension 0 05-29-2008 02:33 PM
