Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Trials Technical Forums > Trials Engine
Trials Engine Cylinder, Piston, Tranny, Bearings, Clutch, Pipes & Silencers, etc.
Old 10-02-2021, 08:01 AM
vaughan vaughan is offline
Question Clutch shim?
Hi, i am replacing the clutch plates in my GAS GAS 300 txt, year is between 2010-2014... there is a spacer between the clutch fingers and the needle bearing, my question is which side of the spacer does the shim sit? i took it off between the fingers and the spacer but it doesnt seem right? Was wondering if anybody had a parts diagram? Thanks in advance.
Old 10-02-2021, 11:46 PM
The hell teams page had parts diagrams but I could not open them the last I tried. Think Paul needs to sign in to his google drive, the order is piston, bearing, then shim against the clutch fingers.
2018 KYB shim stacks Gibnut Enduro Suspension 18 05-18-2018 12:08 PM
Sachs shim 7ID & 9ID, where I can buy? dewenduro Enduro Suspension 11 08-15-2016 02:34 PM
Marzocchi 45 shim advice? motopsycho87 Enduro Suspension 17 10-20-2014 12:47 PM
Countershaft sprocket shim 3hunerd Enduro Engine - 2 stroke 5 03-24-2012 09:29 AM
45mm zoke shim id Ed Ventura Enduro Suspension 1 09-22-2008 05:34 AM
