Old 07-30-2019, 03:36 PM
Iconkj91 Iconkj91 is offline
Default New EC 250 98 owner
Hi everyone. Just bought a 250 ec from 98. With titles. That was th? reason i bought th? bike.
I'm from Belgium. Bought the bike yesterday but it didn't want to start. Pulled the cylinder because i felt it was lacking compression. I was right. Piston doesn't look good. No worries. I was planning a full rebuild anyway. I looked online for Parts availability and it looks good. Am i right thinking this? I'm looking forward riding the bike. Got a KTM Lc4 640sm as daily driver.
Greetings,
Kjelly
Old 07-31-2019, 05:51 AM
Pygmygod Pygmygod is offline
Wow, that looks rooted!
Does pinging/pre-detonation cause those chunks taken out of the top of the piston?
Or a bit of broken metal or debris in the combustion chamber?
Old 07-31-2019, 10:54 AM
Davehuge's Avatar
Davehuge Davehuge is offline
Congratulations on your new bike.
If the piston looks like that how does the cylinder/barrel look?
What about the crankshaft big end and main bearings?
All the best, Dave.
Old 07-31-2019, 11:35 AM
Barrel looks fine. Light scratches so a light hone Will be enough i think. We Will see what th? machine shop Will say.
I Found little pieces of metal so i Will rebuild crank and bearings. Full rebuild. Am i right about all the Parts still available? Been thinking about replacing th? power valve as wel.
Old 07-31-2019, 01:48 PM
Davehuge's Avatar
Wow, with that kind of damage to the piston, you're lucky the barrel isn't damaged.
I have a 2004 EC300 and don't have any problems getting parts, as far as I know you shouldn't have a problem getting parts for your 1998 bike.
I recently fitted a new piston kit made by S3 Racing and I used a full gasket set made by Athena. I'm very happy with the price and quality of both.
I'm not sure if it's worth spending money replacing the power valve (unless it's damaged). I don't think the power valve really wears, it may just need a good clean.
I would definitely check wheel bearings/seals, chain and sprockets, the rear suspension linkage bearings/seals and the swinging arm pivot bearings/seals.
Good luck with your new bike, Dave.
Old 08-01-2019, 05:59 AM
I have a '99. No problem with parts either. I just got a new piston and had the barrel replated. Going to put it together this weekend.
Matt
1999 GG EC 250 Six Days
1999 Cagiva Gran Canyon
2001 Aprilia Falco
Old 08-05-2019, 04:00 PM
Thanks you guys!
Been looking a bit closer to the cylinder and it is shot.
I Found some cylinders in Germany and that will be cheaper then a new nicasil. Only thing i don't Know is if there are any differences between the manufacturing year. On some sites it says all cylinders from 98 tot 15 Will fit, others say 98-99 for example.
Can some of you guys help me out here?
Thanks
New Gas Gas Owner gasgasbloke Enduro Engine 4 stroke (including EFI & Exhaust) 23 10-12-2013 07:15 AM
hi from the uk. not yet a gas gas owner ohffs General Discussions & Announcements 6 08-24-2013 04:14 PM
New owner of a 99 EC 300 boardrider247 General Discussions & Announcements 12 07-11-2013 07:04 PM
New EC 300 owner coachtech General Discussions & Announcements 7 06-13-2011 09:06 PM
New EC/O 200 Owner lankydoug General Discussions & Announcements 3 08-02-2010 09:30 AM
