Old 03-08-2015, 01:02 PM
Fastboysparky's Avatar
Fastboysparky Fastboysparky is offline
Default ec 300 sudden power loss, wont rev
Ok, I have read lots of threads on this but still puzzled. I was on a very bumpy section with lots of loose rocks, I had the throttle pinned going up the gears, the bike was riding it well, I could hear the rocks battering the little gasser but I was having fun. I slowed down to turn onto wet muddy grass and opened her up again, nothing, she was totally flat, no power band. I immediately thought i had crushed the pipe so I stopped to check. It was fine. I have now checked the following
Stripped and cleaned the carb, twice.
New plug.
Removed pv cover and checked for operation. Ok
Checked silencer for blockage.
Checked base gasket for leaks.
Checked reeds.
Checked carb to inlet rubber for perishing and holes
Rode it with ckoke on and off.
Rode it with fuel switched off (till it stopped)
It had new crankcase seals not long ago and oil level is fine
Fuel and oil ratio is as always.
Checked connection to cdi and coil.
When I hold it wot on the road, it gets to certain revs and acts like its stroking, it sometimes tries to go if I wind back the throttle. I am close to trying a match in the petrol tank, it wont fix it but it will make me feel better.
Can anybody help, please.
Old 03-08-2015, 04:29 PM
Check for a broken reed?
Sent from my iPad using Tapatalk
Old 03-08-2015, 05:26 PM
2taddict 2taddict is offline
"Maybe" check the pin that holds the connecting spring to the PV actuator plate has not broken off. Behind cover on R/H side of the cylinder. I just had this problem myself and that's what I found. It was still working to a degree but the exhaust valve was not opening enough when on the gas.
Old 03-08-2015, 05:27 PM
I have checked reeds, they are ok.
Old 03-09-2015, 12:33 AM
barossi73's Avatar
faulty cdi?check insulation on ht lead for chafing?
2013 ec200r
Old 03-09-2015, 04:18 AM
Tigger52 Tigger52 is offline
Sounds exactly the same as when the pin on my power valve actuator snapped off
Old 03-09-2015, 01:33 PM
Just checked the power valve again, looks fine to me. There is a steel wire coming up from engine that moves the pv. This is connected via a locknut, then there is central bolt holding plate to pv spindle. Should there be anything else. It moves to full open as soon as you crack the throttle. Then bounces back when I let off.
Old 03-09-2015, 01:35 PM
I have attached an image. Needs a good clean.
Old 03-09-2015, 02:38 PM
VxZeroKnots's Avatar
VxZeroKnots VxZeroKnots is offline
Looks like it should other than all the black goo.
I'd check the input on the coil again, a poor connection there is what caused similar symptoms in my bike.
Old 03-09-2015, 03:31 PM
I am borrowing a coil, regulator and cdi/ecu tomorrow from a fellow gas gas rider. Will try each one individually. Gonna get rid of the engine map switch then cut off all shabby looking wiring connectors and solder wires together. The bike only has daylight MOT cause the light and loom are shot.
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
EC 300 Rattling & power loss ??? Porkyblader Enduro Engine - 2 stroke 7 09-09-2011 09:11 AM
Your 300 Power loss solution? socalscott Enduro Engine - 2 stroke 3 07-14-2011 08:39 PM
Old gas and power loss? EcEvan03 General Discussions & Announcements 16 04-27-2011 06:40 PM
power loss glassman581 Enduro Intake/Carburetion - 2 stroke 3 03-22-2011 11:19 AM
