Old 05-31-2019, 01:44 PM
Hansen13 Hansen13 is offline
Default Ec 200 signal wiring
I have a 2001 EC 200 that has the block with headlight, killswitch, signal, and horn switch and can't find any diagrams on wiring signals. I am getting it inspected and need some help if anyone knows quickly.
I also ordered a cluster for it with speed/odo/tach if anyone's wired one up interested to see some info!!
Old 05-31-2019, 03:50 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Hi, have a look at this thread... this relates to the 2004 wiring diagram.
This is what my 2004 left hand block looked like...
I'm not 100% sure if it will be the same as your bike...maybe someone else can confirm this?
All the best , Dave.
http://www.gasgasrider.org/forum/showthread.php?t=24485
Old 06-01-2019, 08:36 PM
Thanks! That should help a lot! It seems to be an issue finding schematics for these bikes, but glad to have one that nobody where I'm from has! Thanks!!
Old 06-02-2019, 01:54 AM
Anders Anders is offline
Where do you live? Hansen sounds Norwegian / Danish to me. Please update your profile with your position.
Anders (Norway)
05 300ec Turn Signal Issues natem77 Enduro Electrical & Wiring 1 04-05-2017 05:14 PM
Light and signal switch Waller600 Enduro Electrical & Wiring 5 12-27-2014 06:59 PM
turn signal and tail light problems 06EC300 Enduro Electrical & Wiring 0 03-20-2011 08:06 PM
Turn signal relay 2006 FSE 450 kesnerp Enduro Engine 4 stroke (including EFI & Exhaust) 0 01-14-2009 04:22 PM
