Hi all,
The kick start lever on my Y2k EC200 model has become too worn to use effectively anymore. I notice from the Parts Crossover table, that the YZ250 model can be used on a GasGas but not sure which model. Has anyone any knowledge of specific bikes that have an interchangeable kick start with my bike? I've had it priced at £93 from GasGas uk delivered, which is a bit much just for a lever!! ![]() Thanks in advance. Si |
I fit a YZ kickstarter Yamaha Part No 5NX-15620-00 on my '01 XC300.
Thanks for the tip Erik. Unfortunately the YZ lever has been quoted at near enough the same as the gasser version, so I'll just have to fork out the cash for the right one.
![]() Look after your kick start lever is all I can advise!! Cheers Si |
Did you like the YZ kickstarter better than the stock one. I also heard a KTM kickstarter will fit, does anyone know if this is true? BTW I have an '01 SE250 and the screw is on top, but the YZ screw is on the side!
what is an se250?
Back in 2001 they offered The special edition, I believe it's the same thing as the Dealer edition!
![]() Quote:
http://cgi.ebay.com/ebaymotors/Yamah...61810003r23429 This lever will fit both my '00 and '04 so I'm unsure what you are talking about on yours. The 200 is the same I believe.
Thanks for the reply! Everyone seems to be using the same kickstarter, and that price is the cheapest I've seen! Thanks again!
![]() Quote:
jeff |
The KTM starter will work, I had one on my '00 XC250. Since the knuckle is more narrow, you have to add some shims to the shaft so it can seat on the taper before the bolt bottoms.
Kick Start 07 FSR 450? | GavGav | Enduro Engine 4 stroke (including EFI & Exhaust) | 18 | 04-08-2011 04:33 AM |
450 kick start | gibbo450 | Enduro Engine 4 stroke (including EFI & Exhaust) | 22 | 12-23-2007 05:57 PM |
gas gas 300 kick start. | kingding1976 | General Discussions & Announcements | 5 | 11-12-2007 10:11 PM |
