power valve question
Hi all
I have adjusted my power valve to have a slight preload on the stop and I've put it back together and run it with the rh power valve cover off. When i rev it out the triangular plate doesn't rotate all the way to its fully open stop. Is that normal? My bike is a 2007 ec200. Thanks. |
Kp Kp do a search on it there is a lot of research on that valve .
IF I HAD ALL THE MONEY I SPENT ON DIRT BIKES , I WOULD SPEND IT ON DIRT BIKES |
I've trawled this forum but I can't find an answer.
I would guess you are not going to revit out as much in your garage as you would on the trail so doubt you will get full open in neutral (my thoughts)
And presumably you have pulled the valve & cleaned it? It can be done in place & is pretty easy. There are instructions in the tech area.
I didn't bother cleaning the valves, they looked really clean and then system seemed to move freely when i turned it by hand
Also make sure you do not have too much preload, you just want enough to get the actuator back to the stop. I think one scientific approach was the "slightly compress a soda straw" method ;-)
I was thinking that might be the case but i spent a while making sure the actuator plate only just touched the stop when I released the governor.
So what did you find out? I have the same problem with a 2003 MC250 engine and the PV quickly moves half way and stops rotating. The bike runs pretty well but does not rev out completely.
seem to recall others mentioning the actuator rod can foul or stick in passage,fix was to carefully! tweak rod if this is the issue.
2013 ec200r |
Thread Tools | |
Display Modes | |
Yet another Power Valve/Govenor Assembly question | mp5 | Enduro Engine - 2 stroke | 15 | 07-24-2013 05:32 PM |
Loss of power - suspect power valve | Jonny Halls | Enduro Engine - 2 stroke | 4 | 01-22-2013 09:56 AM |
Power valve bearing question | Rabbitist | Enduro Engine - 2 stroke | 6 | 11-11-2011 01:35 PM |
power valve cover question | geoff g | Enduro Engine - 2 stroke | 1 | 07-27-2009 09:25 PM |
Another Power Valve question | Link | Enduro Engine - 2 stroke | 4 | 01-04-2008 03:48 AM |
