Old 03-23-2022, 02:32 PM
Cstewa37 Cstewa37 is offline
Default Rebuild help needed!
Hi all, stumbled upon an issue today after rebuilding my engine. Currently reassembling my 2011 EC 250 and I'm stumped where these two nipples connect to anything, and can't see where the original hoses go in photos that I took.
I presume they're breathers of some kind, but can anyone tell me where they're meant to connect to??
Chris
Old 03-23-2022, 02:42 PM
SS109 SS109 is offline
They're made to just have a hose running downward to the ground like your carb overflow lines do. At least that's how they are on my '11 EC250R. If you do a lot of deep water crossings I would run the hoses to the top of the air box but that's just me.
Old 03-23-2022, 03:10 PM
SS109 superb, many thanks!! They'll definitely be going nice and high in that case haha!
Chris
Old 03-23-2022, 08:01 PM
swazi_matt swazi_matt is online now
I never had an issue with deep crossings would think the exhaust gasses would always be going out anyway. you also want them to drain out the spooge, not sure if that will work if you run the LHS one up. from factory the LHS is down to the skid plate and then folded back and crimped closed - poss so you don't drip spooge on the trail, but would think you need to let it drain out from time to time
Old 03-23-2022, 09:51 PM
Be aware that those two nipples have different size orifices .
The bigger orifice nipple goes on the right side- transmission vent.
Old 03-24-2022, 10:55 AM
Darkside Darkside is offline
I believe the nipple on the right is a breather and should be run up high so no water can get it. the nipple by the exhaust flange is an oil drain from the power valve and should be run downward
2006 GasGas EC300 2011 KTM 300XC
Old 04-06-2022, 06:07 PM
I believe this is correct. I have always routed the RHS breather tube up and zip-ty it to the rad hose.
I hit a nearly knee deep water crossing once and ended up with milky tranny oil.
Old 04-07-2022, 05:09 PM
I had my breathers down to the skid plate and drowned my bike completely a few times, never had the tranny oil go milky. (it takes very little water to make the tranny go milky)
Rebuild needed? Cstewa37 Enduro Engine - 2 stroke 16 01-18-2022 04:53 PM
Can I do a rebuild myself? stix49 Enduro Suspension 5 09-06-2012 12:39 PM
main bearing failure right side 2006 ec300, rebuild tips needed. hillbilly Enduro Engine - 2 stroke 11 03-16-2012 04:42 PM
Need help on top end rebuild rpduc Enduro Engine - 2 stroke 17 03-26-2009 11:05 PM
Rebuild steve Enduro Engine - 2 stroke 8 01-13-2008 03:06 PM
