Old 04-25-2013, 03:08 PM
Marki Marki is offline
Default Clutch Slave. How much movement?
I'm new to hydraulic clutches so would really appreciate some info.On an EC250 1999 how far should the clutch slave piston move on full lever travel? On mine it seems to be about 2mm, doesn't seem much?
I'm trying to rules out some possible causes to a problem I have with disengaging the clutch.
Old 04-25-2013, 05:30 PM
jaysktms's Avatar
jaysktms jaysktms is offline
That sounds just a little short, mine is 2.4 mm.
13 GasGas 300XC, CLake and now Rekluse
17 Beta 430 RRS, Clake
19 Vertigo 300
03 H-D Nightrain
www.newoodsriders.com
You Can't Out Run Death Forever
But You Can Make the BASTARD Work For It!
Enjoy Life, Have Fun and Play Hard
Old 04-26-2013, 11:03 AM
Thanks for that. It was only a guess on my part, I haven't measured it correctly. It sounds as if its working as it should.
FWIW the clutch will not disengage but it has sat for a while so it might just be the plates are stuck.
Old 04-26-2013, 11:24 AM
jhendr3702's Avatar
mine would do that when parked for a while..
Old 04-26-2013, 12:06 PM
How do you free it? I was going to start it on the stand, knock it in gear, then rev it up while operating the clutch and brake. Probably not the most intelligent approach!
Old 04-26-2013, 12:38 PM
jhendr3702's Avatar
i have a small ramp on my shop.. i would start it, warm it up, roll off the ramp and click into gear and ride it for a few minutes and it would start to work..
probably not the best option either, but always worked..
clutch slave vwboomer Enduro Engine 4 stroke (including EFI & Exhaust) 1 06-12-2012 04:04 PM
Clutch Slave Cylinder Rebuild newgaser Enduro Engine - 2 stroke 5 03-17-2012 08:30 AM
Clutch Slave Cyliner - where's that spring go? mrkartoom Enduro Engine - 2 stroke 4 04-24-2011 10:11 PM
clutch slave movement ? jhendr3702 Enduro Engine - 2 stroke 0 03-16-2011 03:44 PM
Oil around Clutch Slave rickster2 Enduro Engine - 2 stroke 5 08-29-2006 11:27 AM
