Old 09-04-2018, 04:50 PM
Alberto17 Alberto17 is offline
Default What Carburetor for 2004 - EC250
Hi team
My EC250(2004) old carb was having some issues, tried to repair with repair kit but no luck. Fuel consumption was double the average and smoked a lot.
I bought a Keihin PWK 38 airstriker carb to replace the old one, but I suspect this is not the correct carb for this bike.
When I installed it new, it improved fuel consumption, and smoked a lot less, but I experienced following problems:
the idle was super hard to stabilize, whether too high or too low to the point it stalls.
Bike tended to get hotter when in the trails to the point of water boiling sometimes(never happened before)
In lower rpms it lost most of the power, I needed to clutch a lot when doing technical sections or when trying to get out of a heavy hill or something.
So I came to conclusion I bought the wrong carb. I noticed there is a Keihin Quad vent and Keihin Airstriker, not sure if any other out there. Wondering if you can help me determine the correct carb for this bike, ebay link will be of help so I can buy it.
Note; I took a friend's husqvarna 300TE(2016) carb put it on my bike and worked smoothly.
Old 09-04-2018, 05:33 PM
john r b's Avatar
john r b john r b is offline
Sounds like it needs jetting,and float height set. the carb is correct. Quad vent and air striker are the same. Or so I'm told.
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 09-05-2018, 07:28 AM
Davehuge's Avatar
Davehuge Davehuge is offline
Thumbs up
Originally Posted by Alberto17 View Post
I bought a Keihin PWK 38 airstriker carb to replace the old one...
Are you sure it's a genuine Keihin carb that you bought? Many cheap/poor quality carbs out there for sale.
As far as I'm aware... Keihin PWK38 is the correct carb for your bike. AirStriker Quad Vent is correct.
Like John rb says... Sounds like it needs jetting, but first check/adjust the float height. I would only use genuine Keihin Jets.
Can you copy the jetting from your friend's carb? It might not be perfect but should get you somewhere near.
Loads of information regarding jetting on this forum.
Good luck, Dave.
Old 09-05-2018, 07:42 AM
Davehuge's Avatar
Someone please correct me if I'm wrong...
There are 2 versions of the Keihin PWK38 Quad Vent Air Striker carb, the AS1 and AS2.
The AS1 fitted to earlier bikes and the AS2 fitted to later bikes, they're very similar carbs.
The AS1 has a black 'screw on' top...
The AS2 has the top secured with two screws...
Your 2004 bike should have the AS1.
Where do you live? I can recommend this shop based in Holland (they ship worldwide) for Genuine Keihin new/used carbs and spares:
Frank MX Parts https://www.frankmxparts.com/
Hope this helps, Dave.
Old 09-05-2018, 09:55 AM
Tbucket's Avatar
Tbucket Tbucket is offline
It doesn?t matter which one you have. Both of those carb will work just fine.
Check the above mention.
Old 09-05-2018, 09:56 AM
Tbucket's Avatar
Jetting
Float hight
Air leaks.
Old 09-10-2018, 04:01 PM
Attachment 7778
Attachment 7779
What is the difference between those 2 in terms of bike performance?
I am afraid I bought a cheap one(china) and that is why it does not work good
Old 09-10-2018, 04:13 PM
Neil E. Neil E. is offline
No difference, they work the same.
Round top = older model
Rectangular top = newer model
Old 09-10-2018, 04:23 PM
My later model AS2 is shorter in length so I had to machine up an adapter. It was off a 17 so not sure if earlier AS2 are the short type.
Old 09-10-2018, 04:45 PM
Davehuge's Avatar
There's no difference in performance between the AS1 and AS2, both will work great on your bike...
BUT it's essential to get your carb setup correctly, or it won't run correctly or may not even start at all!
Start with the basics, clean air filter, good spark plug correctly gapped, new fuel with good quality 2 stroke oil (usually 2% for full synthetic but check). Check rubber tube between carb and reed block, on older bikes the rubber can perish and split causing an air leak, it's not expensive to replace.
Then check carb, remove main jet and pilot jet, inspect/clean. The hole in the pilot jet is very small and can easily be blocked.
Remove float and float valve, clean/inspect. Rubber tip on float valve can look OK but on older bikes the rubber can harden and it doesn't seal so well.
Check float height, very important before you start adjusting jetting.
Once you've completed all the above start trying different jets. You said it ran good with your friends carb, try copying his jetting, it might not be perfect but should give you a good starting point.
Main things to concentrate on are... Main Jet, Pilot Jet, Needle and clip position, Air Screw.
Good luck, stick with it. Once you get it jetted correctly it'll be a great ride!
Carburetor parts for you Gas Gas Buddmatto General Discussions & Announcements 0 04-20-2017 08:39 AM
Carburetor liamthom Enduro Intake/Carburetion - 2 stroke 9 03-19-2015 02:00 PM
Lectron Carburetor Testing & Adjustment singletracker Pictures & Videos 4 01-12-2013 09:37 AM
balanced carburetor 300ec Enduro Intake/Carburetion - 2 stroke 12 02-21-2012 10:07 AM
