Old 03-01-2009, 02:31 AM
johns2394 johns2394 is offline
Default Gas Gas FSE400 Wheels into a 2001 gas gas ec300 will it work?
Gas Gas FSE450 2003 Wheels into a 2001 gas gas ec300 will it work?
May have a chance to buy some supermoto wheels from a fse400 but will they fit into my ec300 hope some one can help
sorry wrong title
Old 03-01-2009, 09:47 AM
cal_tony cal_tony is offline
Without knowing for sure let me say that I think they will fit.
The rear wheel uses a 20mm axle so that wont be a problem. Depending on the
front fork, some GGs have a 25mm axle and others have a 20mm front axle. The 20 will fit with the 20s and the 25 will fit with the 25s. Further, if the hub has an o.d. of 42mm, it can be made to take either 20 or 25mm bearings.(20x42 or 25x42).
Hope this helps,
Tony
Old 03-22-2009, 02:48 PM
darren's Avatar
darren darren is offline
As he said! I just fitted a set of shivers off a 2007 EC250 with the front wheel spindle, the wheel will just need the bearings changing if you are running the larger spindle.
1998 EC250
07 Shivers
2T racing PV Spacer
FMF Gnarly
2001 EC300 Headlight won't work bexi Enduro Electrical & Wiring 9 03-13-2010 11:12 PM
2001 Ec300 Does It Have A Top End? New To Gas Gas MXR Enduro Engine - 2 stroke 12 06-06-2008 12:52 AM
EC300 wheels firckin Enduro Chassis & Body 1 06-27-2007 05:23 PM
