Old 05-14-2019, 09:10 AM
eralha eralha is offline
Default Piston change, B or C 300 2015
Hi guys, i?m helping a friend changing his piston on a EC 300 2015.
The cilinder is marked as A inside was a B piston, can we put a C or should we put another B?
Thanks.
Old 05-14-2019, 02:00 PM
I'd use an A or B.
Old 05-16-2019, 04:45 AM
lxth7 lxth7 is offline
Hi , I'm doing a 07 300 at the moment.
It is marked A, had a B in it . Im putting a cast B back.
Looking at the ridge at the top of the cylinder, I thought at first it was more worn . But It only measured 72.005.
I'd put back, a B if you can't measure or get it measured.
Old 05-17-2019, 04:44 AM
Hi guys just to let you know, my friend decided based on dealer recommendation that he will go with a C vertex piston, i saw on the vertex faq that the minimum clearance is 0.05mm so it should be fine.
Cheers.
Old 06-04-2019, 01:05 PM
opm22 opm22 is offline
Cheers.
He will probably get better cylinder compression if he get it measured right... The precise answer for your first question is to get the cylinder measured and go with the biggest piston that attends minimum clearance. Service manual says minimum piston play for the 300 is 0.06 mm. The play at assembly of the piston is determined by subtracting the smallest cylinder diameter from the largest piston diameter.
Old 06-04-2019, 04:45 PM
I am sure he did, but just make sure he measured the cylinder in multiple areas and directions because the cylinders do not wear evenly.
piston change Getoviq95 Enduro Engine - 2 stroke 8 07-02-2016 10:03 AM
'03 450 FSE oil change raoufhakam Enduro Engine 4 stroke (including EFI & Exhaust) 1 03-26-2016 03:53 AM
'05 450 FSE Oil Change... bhambaker Enduro Engine 4 stroke (including EFI & Exhaust) 3 03-20-2016 01:30 PM
How do I know when to change piston? lirkipirki Enduro Engine - 2 stroke 7 07-04-2015 06:58 AM
Oil change Vinny Enduro Engine 4 stroke (including EFI & Exhaust) 7 05-25-2011 09:37 PM
