Old 12-10-2017, 07:33 PM
Cball917 Cball917 is offline
Default Hex cap screw m7x30mm?
Where can i find these that are not $6 each? 🤦*♂️
Old 12-10-2017, 08:29 PM
Handle bar clamp?
Old 12-10-2017, 08:32 PM
I just bought some zink plated 8mm x 1.25 x 35mm for $0.71 each.
Bolt Depot.com
Old 12-10-2017, 10:15 PM
CDN Rick's Avatar
CDN Rick CDN Rick is offline
Any good hardware store should have them.
Like the kind of store your grandfather probably went to...
2018 GasGas EnduroGP250
2018 GasGas TXT GP300
1994 Honda CR500 (Ice Racer)
Old 12-11-2017, 01:32 AM
(F5) (F5) is online now
Ahh the Europeans and their quaint range of fasteners. Always wondered why there were so many sockets in a set.
My Beta had exhaust pipe held on with M7s which had 11mm heads and we're so close to the pipe you had to use an open ender and it took about 10 minutes to do them up.
Still. If it weren't for the French we'd all still be using ridiculous sizes with an array of silly fractions and treads per inch.
That and Michelin tyres. OK two things are enough.
Old 12-11-2017, 07:07 AM
I looked for longer than stock 7mm cap screw for several hours and never found them. I needed them to try to grab the last few threads in the clamp after the close threads galled, bound up and stripped. (FYI- it is a great idea to put anti-seize on these threads so they don't gall.) I found longer 7mm hex head screws and added a 1/4 in steel tube spacer so the hex head was outside the recessed hole and the spacer was able to fit inside the recessed hole and put pressure on the flat contact point.
Old 12-11-2017, 12:33 PM
Archibald Archibald is offline
M7's are an odd size. I only found them with hex heads as you did.
Old 12-11-2017, 12:42 PM
Elvis74 Elvis74 is offline
Just for you Americans M7 is a very unusual size here in Europe. I don’t know why gasgas is using it. In my opinion just to make after market business
Gesendet von iPhone mit Tapatalk
Old 12-13-2017, 11:23 AM
Originally Posted by gasgasman View Post
Handle bar clamp?
No it’s the 10 bolts for the triple clamp. I have 8 good ones , one that’s stripped and one that’s broke. Nothing locally has anything close. I can find them in PA , but $5 and some change is pretty expensive for me .
Old 12-13-2017, 06:19 PM
Honestly, when you consider shipping, you should just buy the two local bolts for 5 bucks each.
Idle screw? hamilton Enduro Intake/Carburetion - 2 stroke 10 12-08-2014 02:01 PM
New idle screw bkrjohn Enduro Intake/Carburetion - 2 stroke 1 07-29-2012 03:00 PM
Zip Ty extended air screw Bailey28 Enduro Product Reviews 3 06-03-2011 07:05 PM
200 with screw in the crank???? ramcclure200 Enduro Engine - 2 stroke 3 05-03-2007 11:42 PM
Anyone else ever broken an air screw? lukachuki Enduro Intake/Carburetion - 2 stroke 16 03-12-2007 07:43 AM
