Old 10-07-2019, 12:27 AM
Homer Homer is offline
Default FSE400 Valve timing question.
A question for the 4 stroke brains trust. Would having the valve timing a tooth out on either the exhaust or more likely the intake cam, cause the engine to return a low compression test. Due to my manual being in Spanglish, the valve timing procedure is vague. I'm getting 65psi compression and bike won't start. Heads been done up and rings and piston were fine last time I rode it. Bike is a 2002 FSE400
Old 10-07-2019, 12:40 AM
The auto de compressor on the exhaust cam will drop the compression figure considerably. But to answer your original question yes incorrect cam timing can make the compression appear lower than the actual specs. If you have access to one a leak down tester is a far more accurate way of measuring engine health and will pin point the exact point of compression loss.
450 FSE timing/valve issues foxfire Enduro Engine 4 stroke (including EFI & Exhaust) 16 06-02-2015 06:37 AM
450 Fse Valve Train and Timing twowheels Enduro Engine 4 stroke (including EFI & Exhaust) 4 09-23-2010 06:36 AM
FSR 450 valve check and timing chain ggg Enduro Engine 4 stroke (including EFI & Exhaust) 0 04-22-2010 01:40 AM
fse 400 valve timing ??????? mcludd Enduro Engine 4 stroke (including EFI & Exhaust) 4 08-29-2009 11:54 AM
450 Cam Timing question Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 4 04-09-2008 08:57 AM
