Old 01-22-2014, 03:09 PM
Default whats better old or new
Hi got a 03 ec300 I love the bike to pices but its getting to that point in its life were it needs sort of a restoration doing ie rusty frame, pitted wheel and scratched to fk. And im sure ive bent the forks
My qestion is how much better if not at all are, lets say 2010 on ec300.
As if there is not much in it I would happily bring the old girl back to her former glory
Thanks grant
03 ec300
honda cr500 94
Old 01-22-2014, 03:30 PM
Its an accumulation of updates over the years. Pscook should have some real life feedback as I believe he's just made the change himself.
Engine and chasis wise there have only been minor updates and resvisions over the years. Improvements in fit and finish, subframe strength, peg mounts etc. Suspension wise I'd research some more and decide on what you want. They have come with everything from Sachs front and back through to Ohlins and Sachs, or Ohlins and 45mm Marzocchis, or with some 2011R models 48mm Closed Carts. Then you have the TTX options as well.
A new bike is good, but having just upgraded from my 2010 to a 2013, I'm reminded of how much time I have invested in setting up the old steed, and how much time and dollars is required to get the new one up to standard.
Old 01-22-2014, 04:57 PM
Brian VT Brian VT is offline
I'm in the same boat. '03 EC300 that has never let me down. We've been to hell and back many times together and we know what to expect from each other.
I feel like I should get a new(er) bike but I have no idea how to justify it.
Old 01-22-2014, 05:07 PM
sevenfourate's Avatar
sevenfourate sevenfourate is offline
Newer isnt necassarily better. Its just newer.
It is however more often than not alot more expensive.
Better the devil you know has often never rung truer from my experience.......
Regards Shuv - 2006 EC 250
Old 01-22-2014, 07:14 PM
Beta Steve Beta Steve is offline
Phil got himself a very well set up '11 to replace an older one he just did a very nice resto job on. Search for his posts if interested? I believe he would tell you that while it wasn't perfect [is anything?] it was a huge improvement and well worth the investment of time and money. He certainly is faster now.
Old 01-22-2014, 08:09 PM
pscook's Avatar
pscook pscook is offline
All posts above are correct. Yes, better the devil you know, but the only thing that really changed between old and new is plastics (engine and chassis are pretty much the same). So, it's a bit of a spend to upgrade the whole bike, but understand that it's ten years newer (at least it was for me).
Plus, you get to enjoy the fruits of another's labor (thanks for the suspension, Steve! ), and you get a chassis with that many less hours/miles. A new platform on which to begin your next journey.
I wasn't disappointed in the least, everything is close enough that the pluses outweigh any negatives (of which you will discover with any purchase or rebuild). Negative: Lost the U Rims. Plus: Lost ten lbs (it feels!) with the Excel rims. And so on.
The evolution in suspension alone is worth the change, in my opinion. However, I don't know squat about suspension adjustment, so getting something properly set makes it worthwhile to me.
Phil
(New bike pending...)
Old 01-22-2014, 08:46 PM
waycrazy waycrazy is offline
I am personally fond of old iron myself. I like being able to bang trees without having to worry about new scratches.
03 EC300
The pig...04 XR650L
01 380sx
Old 01-22-2014, 09:44 PM
pscook's Avatar
What about new plastic on old iron? Same thing, effectively (in my view).
Phil
Old 01-22-2014, 10:26 PM
coopernicus's Avatar
coopernicus coopernicus is offline
I've had a 1999 and a 2000 300 and now ride a 2007 250. The '99 and '00 were fairly different because of the forks on the '99 were the 50mm conventionals. It gave it feel that was fine for the open trails but would not turn as well as the '00 with the typical harsh WP 43mm USD forks. Therefore, I spent most of my time on the '00 until I bought the '07 (which is very similar to the '10/'11s). The '07 turns much easier and is more relaxed in the transitions from turn to turn (think "S" turn). With the '07 you have a better feel for where the tires are on the trail compared to the '00. The straight line stability is not as good on the '07 but the steering damper takes care of that. The suspension on the '07 seems to be more compliant and the ergonomics seem to be a little better but that may be due to setup. I've also ridden the '10s and '11s a good bit and they are significantly better than the '07. The "funky" double tube frame on the '10/'11 seems to be more precise (maybe stiffer?) and, to me, is worth the price of admission...There you go, those are my opinions!
Eric
2018 GG 300 GP
2014 GG 300 Racing E
2002 ATK 605 Dual Sport
2003 KX/KDX 220 hybrid
2021 Kawasaki KRX 1000 Trail Edition
1974-86 Vintage Can Ams, SWMs, Puchs, etc.
Old 01-23-2014, 04:29 PM
Thanks some really good info there
Its a hard one, I would like to ride a new (ish) bike and see the diferance to make up my mind I set the suspension up to the best of my knowledge but thats not much lol and could do with stiffer spring for my weigh as im tall and big boned lol
Well its something to think about im not in a rush
thanks grant
03 ec300
honda cr500 94
Whats the difference joedirt General Discussions & Announcements 10 01-16-2012 08:21 PM
whats the riding like in NZ swazi_matt Australia & New Zealand 5 10-16-2011 02:33 PM
Wow..Whats going on with in Spain dcg141 General Discussions & Announcements 4 01-20-2011 03:37 PM
400-450 ECU Whats the Dif?? cal_tony Enduro Engine 4 stroke (including EFI & Exhaust) 10 05-07-2009 02:44 PM
Can't get S-12s Whats next best pursang General Discussions & Announcements 10 08-27-2007 04:02 PM
