Old 08-27-2006, 12:33 PM
gasIdaho gasIdaho is offline
Default Chain and Sprocket specs
What are the specs on the front, rear sprocket, and chain. Stock sizes, dimensions, types, #links, etc. I'm ready to replace the rear sprocket and chain. I may go a bit bigger on the rear sprocket. Any preferences out there?
Mike
05' EC300
Old 08-27-2006, 02:03 PM
Nick's Avatar
Nick Nick is offline
13t countershaft 48t rear 520 chain
Old 08-27-2006, 02:22 PM
MattR's Avatar
MattR MattR is offline
I'm using a 13T Talon front sprocket with a 52T JT rear sprocket and RK 520 X-ring chain. The chain and rear sprocket have held up well, but my front is getting hooked. I had to readjust the chain a couple times for stretch but just minor adjustments. I have run this combination for a year now, so overall each component has held well in my opinion.
This gear ratio works really well for tight, technical trails. Most time I'm running in 3rd and 4th gear, with 2nd and 3rd for corners (depending upon severity). 1st gear is used only for very slow stuff like getting over logs. For higher speed straight sections, my bike is geared a little too low. I'm in 6th gear and reving high at around 50mph.
I'm going to try a 51T or 50T rear sprocket next time. This will make my 1st gear more usable and allow some more speed in 6th gear.
Matt
Current: 2009 Yamaha FZ1
Old 08-28-2006, 12:24 PM
Thx. Any idea on the number of links? Also, I've noticed that when I'm lugging the bike and going into acceleration I get a chain slapping/vibrating noise. It smooths out once my speed picks up. Only seems to do it when I'm in 3rd gear and up. Thx for your help.
Old 08-28-2006, 12:50 PM
eff's Avatar
eff eff is offline
I get the same chain slap noise, and nearly all Gassers I've ridden with do too.
Old 08-28-2006, 07:08 PM
Eric K Eric K is offline
Stock is 112 links.
I use 114 links with 13/50 gearing to run the rear axle further back.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 08-31-2006, 10:41 AM
jeffd jeffd is offline
I posted something on this in an FAQ - look here...
http://www.gasgasrider.org/forum/sho...47&postcount=1
Other manufacturers use a hard rubber for the swingarm chain slider - it would be really nice to find one that "crosses over" and fits on the gasgas.
Part of the chain slap noise is from more slack allowed by the stock chain guide and the result is slapping against the hard plastic chain slider. I like the hard and slippery rubber - cushions the chain and quieter running.
Old 09-01-2006, 04:03 AM
Hawkeye Hawkeye is offline
Mike,
I've been really happy with 13/51T gearing on my 300. Works good for hare scrambles and enduros in the midwest. Moose front and an Ironman rear has given me good life. 50 hours and still going strong. I'm not too picky about chains, any good o-ring or x-ring seems to last about the same. DID, EK, RK are all pretty affordable. Sidewinders are overpriced and it is like buying a used car to get a price out of them.
Hawkeye
"Conviction is a luxury of those on the sidelines."
'13 Beta 300RR - race bike
'02 GG300XC - "Billie Baroo"
'01 DR650
'02 GG 280 Pro
'06 YZ 250
'07 WR450
'00 TT125RL
'94 YZ200 - custom keeper
05 De 300 Specs VORMAN Enduro Electrical & Wiring 9 11-14-2010 06:36 PM
sprocket change will I need a new chain? chucky Enduro Chassis & Body 13 06-08-2010 09:56 AM
ring gap specs jostby Enduro Engine - 2 stroke 9 10-27-2008 06:18 PM
chain slider / chain guide crossover? bondo General Discussions & Announcements 1 09-01-2008 09:13 PM
EC Chain/Sprocket Suggestions? cdn280 General Discussions & Announcements 10 07-31-2008 02:22 PM
