clutch issue
so i had to replace my water pump seal as the coolant was getting into the tranny. pulled the clutch and inner cover.. made the swap of seals... put it back together and now...... my clutch does not disingauge.......... before i took it apart. it did drag a little. sometimes it would almost come to a stall at idle with the clutch pulled in gear. i bled it a couple times and it feels like it should just not disengauging..... anybody??? oh 2012 300ec
2012 gas gas ec 300 WHOA BARB!!!!! 2003 ktm 300exc....for sale 2003 kx 250 woods out..gone 2002 ktm 400exc.... bye bye 2005 yamaha wr 250f...too slow! 2001 ktm 300exc....lemon i think 2003 kx 250...wow but gone... 2008 dr 650..what was i thinking... 1987 yz 125..started it all.. |
When you were working on it was the bike lying on its side? Possibly resting on the gear lever?
I think I might have had it in gear to make getting the inner basket but off...
Did you pull the clutch cover with the bike upright to see if the lever is actuating the pressure plate?
07 GG EC300 11 GG EC300E |
soooo im calling this one my bad...... the washer between the inner basket and clutch hub had fallen off the shaft when i put it back together..... im dumb...
advice on slow starting and clutch issue | Orujo | Enduro Engine - 2 stroke | 0 | 04-23-2013 06:08 PM |
2003 ec250 clutch issue | dirt2road | Enduro Engine - 2 stroke | 12 | 08-17-2012 03:15 PM |
Overflow issue and bog | forgiven | Enduro Intake/Carburetion - 2 stroke | 4 | 10-05-2011 09:20 AM |
Clutch Drag Is Not An Issue! | Rick | Pictures & Videos | 7 | 11-25-2010 07:50 AM |
clutch issue | boostedte37 | General Discussions & Announcements | 2 | 11-09-2009 06:58 PM |
