Excess Vibration
Well last weekend i came into some whoops full noise in third and the bike started to vibrate badly but i heard no bangs clangs or anything, i shut it down had a look but couldn't see any thing, i've since drained the oil and no metal, without pulling it down i don't know where to start. the motor is in a wild hp300 quad but is the same as all 300 , still has good compression but is due a piston and rings, can anyone assist it would be great.
Any loss of power?
Does it make a knocking sound when you have it idling & then give it a burst of rev's? If not ,could just be an engine mount. |
Take the stator cover off and give it a wiggle to see if the left hand main bearing has clearance.
Take the chamber off and have a look into the cylinder to check the top end. Check that the chamber is not just loose as it can make a big rattle noise.
EC300 2019 (11 Gassers owned, many more to go) |
excess vibration
there were no noises out of the ordinary, no power loss just bad vibration, has anyone done a rebuild on one of these and wht did it cost.
Vibration | mikeh | Enduro Engine - 2 stroke | 2 | 04-21-2010 04:18 PM |
foot peg vibration | MIKEWA | Enduro Chassis & Body | 3 | 03-19-2007 08:42 PM |
