Old 08-12-2014, 01:35 PM
savage sausage's Avatar
savage sausage savage sausage is offline
Default clutch bleeding woes
having installed a new clutch in my bike, i went to bleed the clutch but found it was not bleeding at all.
So i took it off the slave cylinder and blew some air in it to pop out the piston, everything looked fine so cleaned it up and pushed the piston back in and tried to bleed the system once again but I cant seem to get any fluid through the slave cylinder.
any ideas??
Old 08-12-2014, 02:47 PM
Moto7man Moto7man is offline
Yes, it can be a b*tch. When I put on my rekluse I had problems. I finally had a KTM tech help me bleed it. He just keep bleeding until the lever firmed up. I'll try to find my thread and post it.
Here is the link, ignore all my whining and go to post 23 by GMP. GMP knows his stuff. Also see post 39.
http://www.gasgasrider.org/forum/sho...h+bleed&page=3
―Comedian Lewis Black
-Unknown Sardaukar
Old 08-12-2014, 06:20 PM
Niall-griffiths's Avatar
Niall-griffiths Niall-griffiths is offline
Bleed it backwards with a large syringe first then bleed normally.
if not i bled my clutch last weekend and I had to cover the clutch fluid reservoir with a towel for it to bleed... God knows why perhaps covering it while pumping the lever stopped some air getting in ??
Old 08-12-2014, 09:05 PM
As with the front brake, you have to pull the lever in a few mm to open the "bleed" port.
It is a built in mechanism to prevent air getting in the system when you flip the bike over.
Old 08-13-2014, 12:36 AM
Maybe that is why I had a problem. Thanks for the post.
-Unknown Sardaukar
Bleeding clutch! Pepperami Enduro Engine - 2 stroke 14 09-22-2013 03:19 PM
Clutch bleeding - how to swazi_matt Enduro Engine - 2 stroke 2 08-09-2011 02:57 AM
Bleeding hydraulic clutch...new line blanc General Discussions & Announcements 7 04-12-2011 03:56 PM
water pump woes skid jackson Enduro Engine - 2 stroke 0 05-16-2009 02:19 PM
HELP! - bleeding hydraulic clutch SpeedyManiac Enduro Engine - 2 stroke 6 10-10-2008 07:12 AM
