Old 10-10-2018, 12:58 AM
Homer Homer is offline
Default 02 FSE400 high idle.
Hi all, new Gasgas owner, picked up a 2002 FSE400, with supposedly 50 miles on the clock, yesterday. After a close look at the bike, I don't think the mileage is correct, but is sure hasn't done much work.
Bike starts fairly easily, considering the small battery, but the idle is way too high, and a bit erratic as well.
Bikes got fresh fuel, 98 octane. I was thinking of running some injector cleaner through it to see if that helps.
I disconnected the cable from the throttle body and no change, so its not a cable issue.
Is there an adjustment on the throttle body to adjust idle?
If not, how do I go about getting the idle speed down?
Thanks in advance.
Old 11-05-2018, 10:45 PM
Well. I got the idle sorted. Took the bike for a run in the forest, and after a little while, the engine started to knock suddenly! Trailered it home, and started pulling bits off. Finally took the head off and found this.
A frigging steel spring washer got into the combustion chamber, and bounced around for a bit, before getting jammed on top of the piston, and bashing into the head.
Luckily the valves and seats are ok. Wonder whats going to happen next????
GG 450 high idle Vinny Enduro Engine 4 stroke (including EFI & Exhaust) 6 06-12-2014 10:32 PM
Idle REALLY high after carb / PV clean SingleTrackMind Enduro Intake/Carburetion - 2 stroke 8 07-22-2013 09:58 AM
ec 300 2005 won't rev high nor idle... hannesd Enduro Engine - 2 stroke 23 12-17-2012 01:52 AM
Very high idle problem rupecopp Enduro Engine - 2 stroke 5 10-22-2007 05:51 AM
Fse400-02 plastic raggamuffin Enduro Chassis & Body 1 01-30-2007 02:34 PM
