Old 07-02-2011, 02:09 PM
dickieshep dickieshep is offline
Default Power valve rattle
I know a lot has been posted on this subject but despite numerous searches I can't find an answer to my question.
After doing a top end and de-coking / rebuilding my power valve assembly it has started to rattle quite a bit.
Question is, if I leave it to rattle will it cause any damage????
Old 07-03-2011, 01:33 PM
After reading how easy the fix is I decided to have a go.
When I took the PV cover plate on the right hand side I didn't need a feeler gauge to see how big the gap was between the actuating arm and the stop. So after just over an hour and a half I had stripped it down and adjusted out the slop.
It has made a vast difference to the running, the bike is so much more responsive off the throttle and seems to get on the pipe a lot quicker.
Many thanks for the fix.
Power valve did it stick? mattdenn Enduro Engine - 2 stroke 11 04-27-2011 04:13 PM
Power valve noise rockrider1 General Discussions & Announcements 5 06-21-2010 02:55 AM
power valve rattle not chain slap gasgasandrew Enduro Engine - 2 stroke 47 06-11-2009 05:24 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
Power Valve Dilemma gasIdaho Enduro Engine - 2 stroke 5 08-18-2007 03:06 PM
