Old 09-16-2012, 06:55 PM
nato nato is offline
Default '12-'13 crossovers
Has anyone had a chance to get a look at the '13 changes yet to see if its worth the coin for the changes to go on their 12's. Im interested in the seat change.
Does this rag smell like chloroform?
Old 09-16-2012, 08:51 PM
jpelaston jpelaston is offline
I can't imagine the seat change is all that ground breaking. I'd get the '12 and buy some '13 shrouds after you break the '12s
Old 09-16-2012, 09:16 PM
I have a '12 but like the 1 bolt access idea to the filter.
Old 09-17-2012, 01:48 AM
twowheels's Avatar
Very easy mod to make to the seat, but you still have to contend with the battery box. Will be interesting to see how the subframe is braced now that the battery box isn't providing lateral support.
Steven Beane #275
afterhourscycle.com
Old 09-17-2012, 01:58 AM
GasTimppa GasTimppa is offline
There is U- shaped aluminium piece in battery boxes place.
There is no such thing as bad weather! Only riding gear is improper or insufficient
When it hurts you know you're allive!
Gas Gas EC 300 Factory Racing 2012
- Ohlins TTX both front and rear
- Rekluse Core EXP 2.0 + Rekluse clutch basket
- Scalvini full exhaust system
- S3 Head
- Trusty adjustable PV cover
That was ultimate setup for me...
Now trying something else for a while...
Old 09-17-2012, 02:42 AM
The seat is already 1 bolt Or do you mean bolt through the top? If so how did you do that one
Old 09-17-2012, 09:15 AM
twowheels's Avatar
It starts out as a single bolt but has been known to become a zero-bolt arrangement at inopportune times
This has been covered in another thread, but here's the short form:
Sharpen the tip of a long screw and drive it up through the foam and the seat cover.
Put a large washer onto a button head Phillips screw and thread it into the nut imbedded in the seat. Thread the screw in far enough to compress the foam and drop the screw head below the plane of the seat.
Finish the job with a large washer and lock nut under the fender.
Steven Beane #275
afterhourscycle.com
Old 09-17-2012, 09:27 AM
Clay's Avatar
Clay Clay is offline
Banned
This is the photo of the crossbrace between the two subframe pieces/P1010008.jpg
Old 09-17-2012, 03:33 PM
Thanks mate. I will look into that one then.
Old 09-17-2012, 04:48 PM
STEVEV STEVEV is offline
now it becomes a 2 tool job to remove the seat. I haven't had issues with mine yet but I've thought about threading a greased bolt into the nut and applying some epoxy with a syringe around the nut. If that doesn't work then I'll be going through the top as well. Too bad a dzus fastener couldn't work. For now it's blue loc-tite and duct tape
crossovers ? wence Enduro Chassis & Body 8 03-04-2011 01:35 AM
