Old 09-05-2008, 08:18 PM
Brian VT Brian VT is offline
Default Spooge spouts (Devap.)
Almost ready to break in my new top end.
I've got 2 power valve spouts to screw in and I just noticed they're not the same. One has a large inside diameter and the other is more like a carb. jet with a very small i.d..
Which one goes on the bottom left or which one goes on the upper right ?
I'm thinking large one on the left for better draining ?
Also, I forgot to order an exhaust spigot gasket. I'm thinking I can run to an auto parts store and buy a sheet to cut one from ? Or...can I get away with the Permatex Ultra Copper High Temp Gasket Maker all by itself ?
Old 09-06-2008, 09:09 AM
Originally Posted by Brian VT View Post
I'm thinking large one on the left ?
I guessed wrong. A buddy looked at his. The pinhole one goes on the left.
Must be to maintain pressure in there ?
Old 09-06-2008, 11:57 AM
Large one on the upper right because its also the trans vent (through the PV pull rod passage).
Use whats left of the old gasket with the high temp silicone.
Old 09-08-2008, 09:56 PM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
I drill all these nipples out to 1/8". I also enlarge the vent hole through the case to 1/8", coming from the ignition.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Power valve spooge SideshowBob Enduro Engine - 2 stroke 4 10-26-2010 11:47 AM
Too much spooge in the exhaust system flybars Enduro Engine - 2 stroke 8 07-26-2010 07:48 PM
spooge problem dirtrider0129 Enduro Intake/Carburetion - 2 stroke 7 07-16-2009 12:19 PM
Spooge-O-Lube Wino Enduro Engine - 2 stroke 0 05-23-2008 01:08 AM
Exhaust Spooge gasIdaho Enduro Engine - 2 stroke 3 07-09-2007 11:44 PM
