Shock & Linkage re-assembly question?
I was re-installing my linkage and shock the other night and ran into a few questions:
First, The two samll cupped washers that go in between the bottom of the shock and the wishbone, basicall where the two meet. How are those washers oriented, does the bigger or smaller diameter face inward or outward? Second, you have the two vertical supports that attach at the bottom of the frame and then go upward and go in between the engine case and the swingarm. My question is, on the rotor side (right if facing) where the big bolt goes through on the top of the wishbone, when I tightened that nut up it did not fully pull it in on the linkage wisbone. Basically there is a small gap maybe .005, but you can see it. Is this normal, or are they supposed to be tight against wishbone? |
The washers are installed convex side out, toward the shock clevis. The inside edges preload and seal on the o-rings. A pain to assemble until you get used to it but seals well.
The pull rods and linkage bracket tighten against the bearing sleeves, with a small clearance. The steel washers retain the o-rings. Be sure the washers are not pinched between the sleeves and the pull rods. |
If you are a more visual type of guy, here is a pic I created one time to help out another rider. Like Glenn mentioned, the washers "cup" the seals. This is the way I always tried to remember it.
The misalignment of the shims on the rocker/linkage is very easy to do. I did it a couple of times. If you remove the shim, take a look on the ID to see if you have a witness mark from clamping on it. It will look like a crescent shape. Hopefully, you didn't torque too hard and bent the shim. If so, you should replace the shim.
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 |
Another tip: Assemble the main rocker and linkage brackets on the bench, hand tight only, just enough to keep the flat washers centered on the sleeves. Fit it to the frame, loosening the main rocker bolt as required to move the brackets. Temporarily install the swingarm pivot to align the brackets/engine/frame, and tighten the bracket mounts and main rocker bolt. Some bikes are a PIA with a tight fit that requires a plastic hammer, others perfect.
2009 SACHS Shock Question | 300XCRider | Enduro Suspension | 4 | 02-16-2011 07:59 PM |
shock and linkage torque settings. | mattlloyd50 | Enduro Suspension | 1 | 08-16-2010 06:23 PM |
Linkage | redrider7202 | General Discussions & Announcements | 12 | 05-18-2010 09:05 PM |
Linkage | redrider7202 | Enduro Suspension | 1 | 05-12-2010 05:34 AM |
Ohlins Shock Question | KTMLew | Enduro Suspension | 9 | 10-02-2007 05:29 PM |
