Old 05-24-2008, 10:04 AM
stay_upright's Avatar
Default Does your clutch drag?
Just wondering of the GG's out there if most have a dragging clutch?
I.e. with the engine idling engaging gear will make it stall or slow the engine speed noticeably - or in gear with the clutch pulled and pushing the bike there is noticeable drag from the back wheel/chain
If you have none of these symptons which gear box oil do you use and are you still on the original clutch?
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
Old 05-24-2008, 04:07 PM
fury1's Avatar
fury1 fury1 is offline
I dont have a problem,06 ec300 stock clutch,shell rotella 15w40 oil,starts easily in gear as well
Old 05-25-2008, 08:26 AM
2 strokes 4 life's Avatar
I dont have any issues on my 2002 GG EC250 with stock clutch plates and springs. I run Amsoil 0W-40 4 stroke oil. I ride in +30 deg C to +5 deg C.
2012 Ktm 300xc
2001 Gasgas EC300
Old 05-25-2008, 08:41 AM
iancp5's Avatar
iancp5 iancp5 is offline
Mine doesn't drag on either Putoline Light Gear Oil or Halfords Dexron III ATF. I also succesfully used a Motorex light gear oil, can't remember the name though.
Old 05-25-2008, 09:32 AM
Eric K Eric K is offline
First off, bleed your clutch slave cylinder.
If that doesn't fix it, then try AmsOil Formula 4 stroke 0W-40 oil.
That cured my '01 XC300 clutch drag.
The '06 EC300 clutch seems to be more tolerant of different oils.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 05-25-2008, 06:20 PM
mountain thumper's Avatar
mountain thumper mountain thumper is offline
mine drags the same way. adjusted the lever all the way. but it still slows in gear with lever in, and moving (off) with level pulled.
how do you bleed it? is it a reverse bleed?
ps sorry if some of my posts have misspells, i switched back to dvorak keyboard
Le Crutan
98 ec250 sixdays, doma, eline pipe guard, zokes shivers from a cr250,fredette racing chain slider, protaper withbarkbusters (SOLD)
FOR THE SECOND TIME 07 EC300 polisport headlight, acerbis taillight ltr pv cover and case saver,trailtech endurance,120z fww, g2 throttle,xr chain puck:
Old 05-26-2008, 02:41 AM
KiwiGasHead KiwiGasHead is offline
I am in same boat....riding in woods yesterday (07 EC125) thought it was just the mud clogging making hard to manhandle (with clutch in and in gear)in uphill snotty ruts after an off...cleaned bike and started it at home and bike jumped when pressing down for 1st, realised it was clutch dragging. Will still start with clutch in and can be pushed but sure have clutch/resistance issues here, bike has done approx 30 hrs from new - do i need a trip to bike shop and will i screw it up riding again this weekend ?
EC125 comin' thru
Old 05-26-2008, 08:32 AM
Try bleeding the clutch by opening the bleed screw on the slave cylinder and pulling the clutch lever in and holding it in. Close the bleed screw. Release the clutch lever. Repeat until you don't see any air bubbles.
The air seems to accumulate at the top of the slave cylinder.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 05-27-2008, 06:30 PM
Kevin_D Kevin_D is offline
Try changing the oil in the gearbox. Synthetic 5W40 motor oil works best in my bike. I ride between 5 to 30 celcius.
Old 05-28-2008, 03:00 AM
Cheers guys - will be trying these remedies over the weekend - first xc race (for me and the bike ) on june 8 so want it in tip top shape.
EC125 comin' thru
Yes my Clutch does drag. (F5) Enduro Engine - 2 stroke 42 04-09-2019 12:11 AM
Clutch Drag? Gas Huffer Enduro Engine - 2 stroke 5 12-11-2007 05:02 AM
05' EC300 Clutch Drag gasIdaho Enduro Engine - 2 stroke 18 09-09-2006 02:53 PM
