Old 06-19-2014, 11:38 PM
farmerj's Avatar
farmerj farmerj is offline
Default No run, no happy :(
I have an '05 DE 300 that hasn't run for a year! I started off with spark problems, and received a lot of help in another thread on the subject.
Now, after a CDI swap, I have consistent spark - and consistent fuel - but the bike will not run! Actually, it will start for a short time once in every 100 kicks, then die.
It actually seems like there is too much fuel - I used to have to use the choke when starting, and now pulling the choke on makes the problem worse. Also, the carb would overflow when on the sidestand, so I adjusted the float.
When I closed the fuel petcock and tried to start it, it would act like it is going to fire for 15 kicks in a row, but wouldn't "catch fire" and run.
Now I wonder if letting it sit for so long damaged the float needle (even though it looks fine visually.) Is it possible for the needle not to seat well, allowing too much fuel to enter the combustion chamber and drowning out the spark?
Or could something in the choke mechanism be damaged?
Just thought I'd try one last time before loading it up and hauling it in!
FWIW, I have:
- replaced the coil
- replaced the spark plug boot
- removed the fuel filter
- checked grounds, wiring, and connectors
- unplugged the kill switch (I think)
- replaced the stator (& flywheel, with a used 2K3 system)
- replaced the CDI unit (with a used unit)
- sprayed some carb cleaner in the carb, removed carb and adjusted float level (fuel was coming out of the overflow, maybe from old gas being in there for too long and damaging the float needle?)
- put in fresh fuel
- tried a couple of different plugs
Old 06-19-2014, 11:50 PM
Rick's Avatar
Rick Rick is offline
Check to ensure that the fuel cap breather is not plugged...........
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 06-20-2014, 01:15 AM
bergerhag's Avatar
When working with the ignition problem did you remove the flywheel? A poorly torqued flywheel nut risk shearing the woodruff key making the flywheel lose its timing. Once in hundred kicks it catches up at the right spot and fires but it will not run.
Old 06-20-2014, 04:29 AM
Moto7man Moto7man is offline
Replace your pilot with a new one of the same size. Also, check your cylinder compression.
―Comedian Lewis Black
-Unknown Sardaukar
Old 06-20-2014, 04:55 AM
Cruiser Cruiser is offline
clean the carb out,, if you have a harbor freight nearby pick up a $45-60 ultrasonic carb cleaner and run the carb in that. Most likely the carb is all junked up in the brass jets from the ethanol. The brass gets fuzzy from it.
Steve
16 Beta 350rr
04 KTM 525 sx/exc gone
03 GG 250 ec-gone
97 GG 250 ec Gone
Old 06-20-2014, 07:06 AM
1RobAusdemore's Avatar
1RobAusdemore 1RobAusdemore is offline
Bronze Level Site Supporter
If you spray a bit of starting fluid or carb cleaner down the spark plug hole does it start up right away?
Old 06-20-2014, 11:21 AM
Ditto.......
-Unknown Sardaukar
Old 06-20-2014, 12:21 PM
Banned
Is it so clapped out that it doesn't have the compression to even kick over and run?
Sent from my SGH-T999L using Tapatalk
Old 06-20-2014, 02:40 PM
I was thinking about that too.
-Unknown Sardaukar
Old 06-20-2014, 10:28 PM
farmerj's Avatar
Thanks guys, I appreciate it! I had pulled the pilot & main jets and they looked fine, no gunk in the carb, but I'm thinking you're right about the need for a good cleaning and can do a pilot jet replacement. Will check some of the other items mentioned and keep on the path!
Jeff
Happy Birthday Rick General Discussions & Announcements 3 11-12-2011 04:50 PM
I'm so happy! Hawkeye General Discussions & Announcements 2 08-19-2011 10:59 AM
Happy Birthday gasgasman General Discussions & Announcements 17 04-10-2011 08:37 PM
Happy Holidays Berkyboy General Discussions & Announcements 18 12-26-2010 04:22 PM
Happy New Year webmaster General Discussions & Announcements 1 01-01-2007 02:11 PM
