Shift lever placement
I did a search and couldn't find anything close since '07,,,,
Anyway, I've got a 02 EC 250 and I can't move the shifter up on the spline far enough to make easy shifts while standing. I have to make an exaggerated foot movement to up shift. The shift lever placement on the spline is limited due to contact with the chain on the Counter shaft sprocket. Do other people have this problem >>>? Is there any fix for this?? Rich |
I had terrible shift issues with my 03 and my motorcycle boots. fixed it with a hammerhead shifter
03 EC300 The pig...04 XR650L 01 380sx |
You can heat it with a MAPP torch and bend it up to what would be a "half spline" amount.
Wouldn't that weaken the metal and ask for a break down?
I have the same problem with my '03 EC200 but I thought it was due to my size 14 boots. My Husky shifter can be moved anywhere you want but I can't get the brake pedal low enough. I'm thinking of buying a good TIG welder and cutting things up and moving them where I want. I looked at the Hammerhead shifters but I'm not sure they would solve both the height and length problem. If you're not 5'9" and size 9 boot I guess you're on you own.
The aftermarket gear lever I use is about half a spline higher than standard.
See the link for a pic - http://www.mainjet.com.au/product_in...products_id=57
EC300 2019 (11 Gassers owned, many more to go) |
The hammerhead helped tons with the shifting . Well worth the money. Still haven't had a chance to address the brake though. Tonight I will take a picture of hammerhead next to the stock. It gives you that extra room you are needing.
If you ever make it to the dry side of the state I will let you try it.
You have to shorten the brake actuator bolt.
I put mine in a bench vise and bent it, cold. No problems for 3 years.
Barry 07 EC250 |
Shift lever crossover | moto9 | General Discussions & Announcements | 12 | 04-05-2010 12:13 PM |
Shift Lever | PEB | Enduro Chassis & Body | 6 | 09-29-2009 05:45 PM |
Longer shift lever for the FSE??? | McGuiver | Enduro Engine 4 stroke (including EFI & Exhaust) | 7 | 01-08-2009 08:04 PM |
