Old 08-22-2023, 10:37 AM
Tech Tech is offline
Default 18 EC300 Battery not charging FIXED
**Regulator/Rectifier is putting out DC voltage...rising & falling w/throttle
**Relay functioning correctly
**Motor & starter running perfectly
**Battery..new AntiGravity 8 cell small case..... runs down after each ride...I sometimes have to kick start. Last ride battery was at 8.6 volts at end of ride.
Possible causes yet to be verified:
#1 Diode at relay - Below is a quote from an old thread indicating it could be the diode attached to the relay.
#2 Loose/faulty connection - I have traced most connections but could have missed something.
Originally Posted by ditezz View Post
I know its an old thread but anyway.The Diode module is used to isolate and protect the two DC supplies ie The stator supply and the Battery supply.
The battery needs to be charged from the Stator.The Diode Module ensures the stator can only flow voltage into the Battery circuit but the battery cannot feed back into the Stator circuit (lights etc).
If you diode Module was missing your battery would not charge which is your Problem.
As for running the motor without the battery can destroy your electronics through over voltage.The battery is ,as well as being a load it acts like a regulator
I am at my wits end...& my wits are old & weak!!
Thanks everyone!!
Old 08-22-2023, 01:00 PM
blitz11's Avatar
blitz11 blitz11 is offline
Thanks everyone!!
Have you tested the diode? It's not clear from your post.
Old 08-22-2023, 02:08 PM
Have not tested the diode. Not sure how to do this.
I have a Fluke 88V meter.
Also, I am having trouble reading the wiring schematic. I do not understand how the Battery/Relay/Starter schematic interfaces with the rest of the wiring schematic.
Old 08-23-2023, 09:21 AM
Moto7man Moto7man is offline
Default Diode Test Video
Caution I saw this video on youtube about testing diodes but I don't know anything about this process, so be careful and use at your own risk.
https://www.youtube.com/watch?v=9LwDPHvzH90
―Comedian Lewis Black
-Unknown Sardaukar
Old 08-23-2023, 09:23 AM
Default PM Member Neil E
PM Member Neil E, he is the electrical guru on this board.
-Unknown Sardaukar
Old 08-23-2023, 01:03 PM
More testing @ diode....view "J" on wiring schematic
**Varying DC voltage on Red wire while bike is running..14.3 max
**Static DC voltage on Red/Yellow wire while bike is running & not running. Same voltage as + - on battery.
**No readings on White/Black or Green/Yellow wires while bike is running or not running
Old 08-23-2023, 08:03 PM
Neil E. Neil E. is offline
Moto7man thanks for the compliment, but I'm not versed on the newer bikes. All I have is the '18 wiring diagram in the owner's manual. It is severely lacking in details. Does not show the stator. Does not show a diode module.
The only diodes I am aware of on the older bikes, are the ones in the voltage rectifier/regulator. The bikes have an AC powered CDI.
I'm super busy right now with no time to investigate. I don't know where to get a proper wiring diagram. The red wire voltage at 14.3 sounds good.
Old 08-24-2023, 11:19 AM
blitz11's Avatar
Can someone post that wiring diagram for the year in question?
Old 08-24-2023, 04:43 PM
Diagrams too large to download.
Rieju Linkhttps://static1.squarespace.com/static/5f7ca7769bb53012f2be84b3/t/5f7f666b728d3904359e4333/1602184895623/2021+Rieju+MR+Racing+Owners+Manual.pdf
Pages 15, 16, 17
If that doesn't work try
https://www.rieju-usa.com/downloads
Thx for your help
Old 08-24-2023, 04:47 PM
2018 forward are all the same.
'18 EC300 (battery not charging) TerraMoto Enduro Electrical & Wiring 12 07-17-2020 10:03 PM
2018 EC300 Speedo Battery Code malin Enduro Electrical & Wiring 1 07-31-2018 03:31 PM
not charging battery OLD.IT Enduro Electrical & Wiring 2 06-21-2015 03:01 AM
Charging phone on 2011 EC300 Quigs Enduro Electrical & Wiring 9 03-07-2015 12:55 AM
Battery Not Charging GLantern Enduro Electrical & Wiring 6 08-25-2013 03:45 PM
