Old 04-24-2010, 02:11 AM
itsagas itsagas is offline
Default 2005 FSE450 wont start
Has anyone else had trouble getting there bike to start.
Recently I re did the valve guides and put in new ring. However upon reassembly the dam thing wont start. It will using aero start and will run fine.
Have I missed anything?
Itsagas
Old 04-24-2010, 01:39 PM
ferguscawley ferguscawley is offline
Re-check your timing. You are more than likely a tooth out on one of the cams.
Old 04-25-2010, 04:02 AM
Smile Timing
With the timing, is there a trick to setting the Cam timing. The books a bit vague.
What Ive done :
1. set engine to TDC
2. set the cams so the three holes (2 outside, with 1 small in the centre)
3. the marks with the arrows (2 straight up and 2 pointing towards each other)
My question then is, which way should I go. Back a tooth or forward?.
Thanks mate.
itsagas
Old 05-01-2010, 04:03 PM
bergerhag's Avatar
If bike runs fine after starting it using aerostart, then your cam timing is likely ok. It might be a sensor problem, get the bike hooked up to a diagnostic pc and verify your efi and sensors. Also check intake for leaks, spray your aerostart near the intake rubber with engine running, any shift in revs indicates a leak.
Old 05-16-2010, 05:13 AM
Thanks for that. I have one more twist though. The bike will start fine when cold, but with difficulty when at operating temp.
I've checked Cam timing and it was out by only 3deg.
I will try the leak test and will get it plugged into a computer.
any other thoughts or help would be great.
Regards
Dean
Old 05-16-2010, 08:38 AM
bergerhag's Avatar
The Gasser 4strokes are very picky when it comes to warm starts. Open the throttle ever so little, just barely, and then hit the e-button. If that doesn't help, recheck your valve play.
02 EC 300 wont start GENO 300 Enduro Engine - 2 stroke 0 09-21-2009 10:02 PM
EC200 wont start Skele Enduro Engine - 2 stroke 25 09-06-2009 10:34 AM
wont start clerky clerk Enduro Engine - 2 stroke 8 11-01-2008 01:18 PM
2000 Xc 250 wont start In mesa arizona justinmanus Enduro Engine - 2 stroke 9 12-25-2006 04:46 AM
