Old 12-18-2011, 04:52 PM
andykr87 andykr87 is offline
Default 11 300 kickststarter problems
i havent had time to fix my estart yet so ive been kicking my gasgas. today i guess kick starting it bent it. kinda weird. anybody else have this problem and is there a stronger one available or a recall??? was a total bit#h kicking it like that with the trails muddy today.
always look awesome wet
Old 12-18-2011, 06:19 PM
MJC MJC is offline
It's only a matter of time before it breaks worse than it already is. Mine broke @20hrs and I replaced it with a new Yamaha kick starter assembly.
http://www.ronayers.com/Fiche/TypeID.../Group/STARTER
#18 is the part you need. It's a direct bolt on and is a much, much better piece than the oem starter.
Old 12-18-2011, 07:58 PM
Mark Berg - CPD's Avatar
Mark Berg - CPD Mark Berg - CPD is offline
Default Kickstart
Contact your local dealer, that will be under warranty from Spain. We have in stock, just tell your dealer about the issue.
Mark Berg
Old 12-18-2011, 08:24 PM
mcnut's Avatar
mcnut mcnut is offline
Ours did the same thing with 25 hours on the bike. We also replaced it with a YZ kicker.
Old 12-20-2011, 06:14 AM
Default new kickstart
New kickstart vendor for 2012 that is better, stronger, and will be cheaper. Delivery end of February and should work way back to 1996
Mark Berg
Old 12-20-2011, 07:12 AM
mcnut's Avatar
Hopefully a new footpeg vendor too. The '11 footpeg is about as durable as peanut brittle.
Clutch problems gaser Enduro Engine - 2 stroke 5 11-15-2010 07:51 AM
CDI connection problems. HELP!!! ejas66 Enduro Electrical & Wiring 4 02-18-2009 03:16 AM
07 EC 200 Jetting problems cooganbr Enduro Intake/Carburetion - 2 stroke 4 08-15-2008 04:29 PM
03 300 Problems Ryan#87 Enduro Engine - 2 stroke 3 06-15-2008 10:28 AM
06' ec 200 problems speed addic Enduro Engine - 2 stroke 0 02-25-2007 06:44 PM
