Old 09-01-2011, 10:19 AM
Rabbitist Rabbitist is offline
Default Swing arm question
Hey guys another question for all you gas gas gurus out there.. Should my swing arm have any play in it? Took the wheels out to replace the bearings and noticed theres a bit of play in it side to side..? I have the bolt torqued up to 82 which I believe is right..? but still a bit of play in it?
Cheers luke
Old 09-01-2011, 12:05 PM
Brian VT Brian VT is offline
Shouldn't have much, if any, play.
When was the last time you had it off to grease and check the bearings ?
Todd5774's Avatar
Todd5774 Todd5774 is offline
Time to replace the bearings I think.
02 300ec- 50mm Marzocchi cc forks, 2010 plastic.
Now a 250cc.
Old 09-01-2011, 05:33 PM
cbutler's Avatar
cbutler cbutler is online now
Yep time to replace them.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 09-01-2011, 11:34 PM
bergerhag's Avatar
if it slides sideways on the swing arm bolt, and is not wiggeling sideways at the wheel end, it is probably nothing wrong with your bearings. There must be a slight sideways play else the swingarm would not freely move. It should not be much and if you are seeing more than 1 mm there is something wrong.
Over time your swingarm will see some wear on the inner faces of the mounts where the swingarm fits to the inner flanges of the needle bearing shafts, as dirt and grit can get there. There are no bearing surfaces holding the swingarm sideways, hence the play. You can measure the play between the swingarm and the shaft flange with a feeler gauge.
swing arm shaft stuck whodat Enduro Chassis & Body 17 03-22-2009 07:53 AM
Swing Arm Bolt Removal RPB111 Enduro Chassis & Body 5 12-28-2007 04:18 PM
07 swing arm ? REVERUP Enduro Chassis & Body 12 04-29-2007 08:59 PM
