Old 01-22-2009, 06:44 AM
prk03's Avatar
prk03 prk03 is offline
Angry Stripped bottom of Ohlins
I stripped out the bottom attachment of Ohlins shock. There is mention of a kit to repair. Will try and contact Ohlins today. Anybody else done this. I was using the torque rachet but went a little too much.
Old 01-22-2009, 07:12 AM
According to Jerry at Ohlins USA its fairly common, hence the repair kit. Its basically a steel insert for the stripped thread side of the clevis. If your using anti-seize on the bolts (you should), the torque should be 20 - 30% less than a dry bolt.
Old 01-22-2009, 12:02 PM
PEB PEB is offline
I was always scared tightening that bolt for fear of what you did. Good luck with the repair.
Old 01-23-2009, 12:25 PM
prk03's Avatar
I talked to Ohlins and got a email from Jerry. He was not aware of a "kit" to fix the stripped out clevis. A friend knew of a first rate machine shop and took it there. They put in a heli-coil and it looks perfect. It is a stainless steel insert. Probably the same thing as the "kit" from Ohlins. The machine shop states this is stronger than just the aluminum threads. Will give a report when put back together. However be gentle with this bolt. It doesnt take much. Final cost 50$ and feeling stupid.
Old 01-23-2009, 12:33 PM
tomatoe333 tomatoe333 is offline
Is there any reason to not use a slightly longer bolt, and a nut on the far side of the clevis? I discovered the source of the rear suspension play in my bike this afternoon, when I removed the shock bolt and the threads from the hole came with it.
Old 01-23-2009, 12:41 PM
Well thats pretty damn strange because a few years ago they sure knew of it.
With your Helicoil fix is the inside of the clevis smooth and flush? The cup washers are a compression fit and it will be next to impossible to assemble it if anything protrudes on the inside of the clevis.
Old 01-23-2009, 01:10 PM
Boomhauer's Avatar
Boomhauer Boomhauer is offline
You could also contact Les at LT-racing. Who knows he might have something in stock to fix it as he is an Ohlins pro.
LT-Racing
"Making You Faster since 1980"
PH: 360-871-2259 | Email: info@lt-racing.com
Old 01-25-2009, 08:53 PM
prk03's Avatar
Talking
I just finished putting the shock back on and no problems. I made sure the machine shop understood the importance of the heli-coil being flush with the clevis. I am waiting for my carb to come back from R-B designs. Looking forwards to another trouble free racing season.
Old 01-25-2009, 09:03 PM
prk03's Avatar
Thumbs up
Regarding using a longer bolt , that will not work because of the lack of space due to linkage. Thanks for all the input.
right side PV vent stripped....help joey11 Enduro Engine - 2 stroke 5 06-20-2009 02:38 PM
Stripped screw in gas tank prk03 General Discussions & Announcements 2 06-18-2008 11:19 AM
stripped hex head nhrider General Discussions & Announcements 11 05-28-2008 12:06 PM
Stripped Brian VT Enduro Suspension 4 12-09-2007 09:06 PM
