Old 11-06-2015, 08:52 PM
Scruse24 Scruse24 is offline
Default Carb overflow question
Just curious as it happened on my ktm...has anyone ever had their carb keep overflowing after changing premix ratios? Say from 38:1 to 50:1?
Old 11-07-2015, 07:18 AM
Brian VT Brian VT is offline
The float needle isn't seating/sealing. If you use gas with ethanol in it then the rubber tip of the needle may be degraded.
If it doesn't have a rubber tip then there may be some crud in there or the float is sticking.
I can't imagine how the oil ratio could be the cause of this though.
Old 11-07-2015, 05:48 PM
I'm thinking that different premix oils have different viscosity.
Old 11-08-2015, 11:18 AM
shang shang is offline
I've had several bikes do this to me this year. In all situations the float needle looked perfect. I replaced them anyway and the problem stopped. It's just ethanol fuel....
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1983 Yami Tri-Zinger
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 11-08-2015, 01:42 PM
I run 93 ethanol free. I'm going to check the float level. Might go ahead and replace the float needle too.
carb question bowhunter007 Enduro Intake/Carburetion - 2 stroke 26 03-13-2013 06:57 AM
Carb question jpelaston Enduro Engine - 2 stroke 4 09-17-2012 08:07 PM
Anyone fitted a carb? & starter clutch question sgoaty Enduro Engine 4 stroke (including EFI & Exhaust) 5 05-25-2011 05:02 AM
2010 carb question GG27 Enduro Intake/Carburetion - 2 stroke 13 12-14-2009 11:42 AM
Carb Question Gas Stu Enduro Intake/Carburetion - 2 stroke 2 08-22-2007 04:33 AM
