Old 02-07-2024, 05:24 AM
gassumies gassumies is offline
Default EC 300 cylinder max wear limit?
I bought the bike with no history when the piston was last changed.
I dissabled the top end,
turns out the previous owner had installed the A size piston (cylinder is stamped A but the bike is from 2009)
It has some light up and down marks but i cant feel them with my fingernail,
probably from the too small piston slapping around
The cylinder measured 72,03 and the biggest piston from vertex of wossner is for 72,02 bore
Is the coating too thin and break off?
or will the 0.01mm extra clearance cause it to slap around more and ruin the cylinder for good?
Piston/Cylinder Wear Question (with pics) gascadia Enduro Engine - 2 stroke 6 11-08-2021 11:19 AM
Vapour Engine Temp and RPM Limit values? Hicksi Enduro Electrical & Wiring 1 12-20-2012 02:38 PM
Pistons worn out limit motohellrider Enduro Engine - 2 stroke 9 11-20-2011 07:22 PM
Stupid Question? Rev Limit? Jakobi Enduro Intake/Carburetion - 2 stroke 5 11-13-2010 05:36 AM
300 EC RPM limit? Hollywood Enduro Engine - 2 stroke 9 09-10-2008 07:59 AM
