Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > Injury & Recovery
Injury & Recovery Injuries, Health Issues, Vision & Body Repair
Old 04-25-2012, 12:23 AM
jgas jgas is offline
Default Hands go numb.
I just found out I have Carpal Tunnel and the hole in the elbow where the main nerve runs through needs to be drilled out on my left arm. Gotta have surgery for Carpal tunnel and also on the elbow. I can only hang on tight for about an hour before my hand gets too weak to ride. Until I get around to the surgery, I have figured out a temporary "fix". I ice my hand and elbow right before a ride. If possible I return to my truck to re-ice it every hour or so, for about 10 minutes. Seems to help quite a bit.
I also glued a peice of velcro 2 sided tape around my hand grip, and the other peice to my glove. I glued the velcro stuff over the whole palm and on my pinky and ring finger but not on the other fingers which need to clutch and regrip.
It's a bandaid to keep me riding, and surgery is the only fix, but I can ride a bit longer and faster with the hand velcro-d to the grip. Just thought I'd pass it along.
Jeff.
Old 04-25-2012, 05:04 AM
Cruiser Cruiser is offline
I've been using the "C-trac" traction devise and it helped a lot. I have had symptoms and the minor symptoms are gone.. I do not use the devise the instructed 3 times a day.. but just once a day.. 3 times would do much better.. this may help out for a while.. especially if you follow its instructions.. unlike me. which I am now doing again..
http://www.carpaldoctors.com/?gclid=...FQIQNAodTnANtQ
Steve
16 Beta 350rr
04 KTM 525 sx/exc gone
03 GG 250 ec-gone
97 GG 250 ec Gone
Old 04-25-2012, 10:45 AM
flybars flybars is offline
Good idea about the velcro. I've had the carpal release surgery and have not had a problem since. Good luck with your surgery.
'14 Beta 300rr
'05 GG DE300
'03 GG EC250
'01 XR440
'09 FZ1
Old 05-01-2012, 06:57 PM
waycrazy waycrazy is offline
I have had the release surgery done on both hands. Unfortunately I let it go for way to long and the surgery didn't help me as much.So my advise is don't put off surgery. Get it done right away for best results.
03 EC300
The pig...04 XR650L
01 380sx
Old 06-14-2012, 02:17 PM
oregon pampara rider oregon pampara rider is offline
I added fasstco Flexbars to my bike and that has helped with my numb hands a lot for me.
03 300 ec, 03 pampera, montesa 315, thanks to ltr suspension,and grand prix
Old 06-14-2012, 04:26 PM
davedunaway's Avatar
davedunaway davedunaway is offline
Default Numb hands
I also run flex bars finds it helps a lot. The other thing I found just as effective for me was switching to oversize grips. Scott makes them. I have quite large mitts and my problem was over gripping because my the stock grips were just to small in diameter. The larger grips allows me relax my hands on the bars a lot more.
Dave
Old 06-14-2012, 06:48 PM
erniebearskin erniebearskin is offline
I fitted the ktm phds system and it works well. Although I have never tried them, Flexx bars seem like the ultimate solution..
Bryan
2013 Husaberg TE250 - Current
2011 GasGas EC300 - OLD STEED
2011 Husaberg FE390 - OLD STEED
2010 Yamaha WR250F - OLD STEED
#53B
I dream of a better tomorrow, where Chickens can cross the road, and not be questioned about their intentions.
Old 06-14-2012, 09:36 PM
Onespeed's Avatar
Onespeed Onespeed is offline
Yah dont death grip the bars...hold on with your legs. When I first started riding dirt again my arms/hands would get numb....after I focused on using my legs more the pain didnt stick around as long. Just relax and dont forget to stretch.
06 KFX 400/ Kdx soon- Wifey
03 KX 65(sold)/ 04 YZ 105- Son
10 YZ 450(sold)/ 12 EC 300 (GG)
STREET_ GTR 1400 (The Connie)
93 KDX 200 (Katie)
Old 10-02-2012, 12:56 AM
Default Update:
Thanks for all the input. I talked a VA doc into giving me a small steroid injection in my elbow. Worked wonders! I've had about 50 of those in my low back, and 10 or so in my left shoulder, some worked and some didn't. He didn't like doing Cortisone in the elbow, said it could be harmful, but he did a small amount and it helped. That confirmed to me what they already thought, that 80% of my problem is in my elbow rather than carpal tunnel. If my problem comes back in force I'll have the elbow surgery and probably forgo carpal tunnel.
In the mean time, I've been experimenting with gloves and grips. I'm using ProGrip Rally grips. They are huge! Hard to get used to, but now I love them. They tend to come loose from the bars easier. The best glue seems to be Shoo Goo. Pro Grips and Renthals glue works on other grips but not these. I guess they are too flexy or something. I have also been using some thin rubber gloves from Harbor Freight. They are only 5 bucks, and wear out pretty fast and tear but they are so tacky that when I pull my hands off the grips they are stuck a little. I can relax my grip and still hang on ok. The gloves have no protection on the backs. I might try gluing some thin strips of material on the backs of the fingers.
Old 10-02-2012, 08:41 AM
You should not get more than two Cortisone shots in the same area, its bad for the bone. If that doesn't do it then you need surgery. It functions as a super anti-inflamitory that allows the tissue to heal (if it can heal). I had tendonitis in my wrist and was lucky one shot worked. The oral drugs tore my stomach up.
Flexxbars! What more can I say? Ever hear ny complaints?
For problem grips, and reusing grips, try one layer of friction tape barely overlapped and overlapping the bar end slightly. Then coat with Shoo Goo.
