Old 10-03-2017, 12:22 AM
Fojjer Fojjer is offline
Default Generator capacity on a ec250 -15?
Hi!
Enyone here who knows how many Watts of light i can put on the bike in question?
Going trailriding in the dark. Planning on leaving the standard headlight (35W) as it is and just hang on extra leds on handelbar/fender connected to the bikes battery. Dont want to end up with an empty battery in the woods at winter...
/Mathias
Skickat från min SM-G930F via Tapatalk
Old 10-03-2017, 12:50 AM
Anders Anders is offline
Originally Posted by Fojjer View Post
Hi!
/Mathias
According to the Norwegian importer, you can have a total load of 65W. I use the Endurotech headlight on my '15 EC200, it is rated at 4.5A (which is 54W at 12V), I have no tail lamp and no other loads. I use switches to select either full headlight or low headlight + grip heating.
I addition, I have a battery powered helmet lamp.
Old 10-03-2017, 10:58 AM
Neil E. Neil E. is online now
I you leave the stock headlight switched on, you are wasting much of your stator output. Mount some LED lights and only power them.
Old 10-03-2017, 12:32 PM
Thank you both!
My idea was to have a street legal (swedish law) headlight on the road to driving area near by. But you may be right; just a waste of watts. Better to fix a proper led alternative.
I'm having a pair of helmet lamps on china mail. Will be intresting to see how mutch light i need. Have to start with something!
Thanx again!
/Mathias
Capacity advice please 32:1 General Discussions & Announcements 13 02-26-2017 05:58 PM
2010 gasgas ec300 Sachs fork oil capacity? Woodgates Enduro Suspension 3 06-24-2016 05:44 PM
300 EC generator output. Barbs Enduro Electrical & Wiring 2 05-23-2015 10:34 PM
